Onkyo tx-nr808 resistor - diyAudio
Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 28th December 2015, 08:34 PM   #1
hpewyo is offline hpewyo  United States
Default Onkyo tx-nr808 resistor
Having trouble finding a resistor for my reciever and I'm lost without it.
P H R
MPR 5W
R22J X2
Any help is appreciated!
Old 30th December 2015, 04:35 PM   #2
Speakerholic
Cal Weldon's Avatar
Moved to parts
planet10 needs your help:
Let's help Ruth and Dave
Old 30th December 2015, 06:11 PM   #3
arnyk is offline arnyk  United States
Banned
P H R
MPR 5W
R22J X2
Picture?
Old 30th December 2015, 08:49 PM   #4
it was center pin common and a triple pin setup plate resistor
Old 31st December 2015, 10:21 AM   #5
Banned
The markings suggest that it may be a dual 0.22 ohm 5 watt resistor.
You could then replace it with 2 resistors, one lead each soldered together for the required 3 terminals.
These show up in the emitter circuits of SS output stages, and are prone to be fried when there are other failures in the circuit. I'd expect to find one or more fried transistors in the same amp channel.
Old 31st December 2015, 06:34 PM   #6
irribeo is offline irribeo  Netherlands
or ebay for example:
dual emitter resistors | eBay
Onkyo tx-nr808 resistor hpewyo Everything Else 6 4th May 2016 02:42 AM
onkyo TX-SV535 Carlosraj Solid State 5 4th October 2015 10:53 AM
onkyo tx nr636 harleyman58 The Lounge 3 5th September 2015 01:41 AM
Onkyo TX-NR808 fault robtheviking Solid State 0 28th May 2015 10:59 AM
Onkyo TX-930 mplehning Solid State 11 17th May 2008 11:07 PM
Copyright 1999-2017 diyAudio
