Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Selectronic Rcore transformer
Old 19th October 2017, 05:42 AM   #31
scoobis is offline scoobis
Originally Posted by TonyTecson View Post
unless you are building an equipment intended for medical or life saving,
i can not understand why you are too concerned...
not sure if that was directed at me or not...i'm not concerned at all actually. the projects i would plan to put this in will likely pull 100ma so i'm going to be no were near 100% load.
this all steamed from the sellers on ebay not being able to give the correct specs for the transformers, and no specs other then current and voltage were posted. so i got one to test it and post the specs.
in fact i was told that the rated voltage was at 50% load by the seller... i kid you not.
anyway think the whole idea is to see if there usable or not, and it seems they are.
Old 19th October 2017, 06:27 AM   #32
TonyTecson is offline TonyTecson  Philippines
TonyTecson's Avatar
then just do it... no need to be overthinking things.....
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 19th October 2017, 07:31 AM   #33
who is over thinking. ... hmm maybe you haven read the whole thread.
i got it specifically to test it and post the data on it as it was not otherwise available for it and then use it on a project. sadly it too 2 months for them to deliver this transformer, so i used another transformer on the project it was intended for.
i've posted the test results as promised for others to reference since the data was not otherwise available.
the transformer will sit on the shelf till its suitable for another project.
Selectronic Rcore transformerHide this!Advertise here!
Selectronic Rcore Transformers RCruz Power Supplies 80 21st April 2017 06:46 PM
Determining amp rating of transformer from Crate GFX-15 transformer pdavis68 Instruments and Amps 2 24th June 2015 12:46 AM
WTB Selectronic R core tranny Marra Swap Meet 0 9th October 2013 10:49 AM
http://www.selectronic.fr pellesmil Power Supplies 38 10th June 2013 05:24 PM
WTB 2 Rcore 22 or 24 vac dual sec. AVWERK Swap Meet 2 27th December 2010 08:27 PM
