Germanium output driver transformer use - diyAudio
Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 26th November 2015, 05:15 PM   #1
Ggizzy is offline Ggizzy  United States
Default Germanium output driver transformer use
Good afternoon,
I gutted a 1967 Packard Bell RPC-39 console. I kept the marvelous Star trek space-age "Solid State" radio but discarded the power amplifier.
The power amplifier was germanium transistor output driven, but I have long since discarded the transistors and I never had the schematic. I kept the decent-sized EI 50V PT and the output driver transformer pair. The markings on these, as shown in the picture are:
606 is the EIA code of Woodward-Schumacher, and the console is from '67 so its reasonable to assume the transformer is from '65. My question is- before going to the length of determining the turns ratio and impedance- should I even bother? Is there a cost-effective use of these in transistor output instrument amps? Is there engineering use outside of audio?
Old 26th November 2015, 08:54 PM   #2
JonSnell Electronic's Avatar
Send a message via Skype™ to JonSnell Electronic
The driver transformer doesn't mind whether Ge or Si transistors are employed as the bias is set up separately. Possibly the transistor were OC16? I still have stock of some for repairs in my workshop. Best to keep things original if possible.
The PT is fine for other uses but the driver is a driver and possibly 16 : 1 ratio. Stick a 5volt sine-wave at 1kHX on the primary and measure the outputs. That will give an indication.
Support for Flying Mole Class D, Allen & Heath, Valve amps, older designs & 2CVs.
Old 26th November 2015, 09:29 PM   #3
Thank you!
Germanium output stage NIC1138 Solid State 29 19th August 2014 07:28 PM
Germanium transistors work fine in output stages ? aldovan Solid State 32 14th May 2013 02:46 AM
Difference between SE output transformer and push-pull output transformers hilbert_mostert Tubes / Valves 12 8th March 2009 06:10 PM
3C24 in a SE output stage - output transformer impedance recommendation !!! aldovan Tubes / Valves 15 6th September 2008 11:18 AM
Can An Output Transformer Change A Voltage Amp's Output Impedance From 0.1 To 47 Ohms kelticwizard Everything Else 11 25th March 2007 06:17 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
