Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Cheap, simple and very good diy interconnects
Old 15th February 2004, 05:41 PM   #1
Mad_K is offline Mad_K  Norway
Mad_K's Avatar
Default Cheap, simple and very good diy interconnects
While it didn't seem like a whole lot of of people took me seriosly when I told you about the "GainWire" ( http://diyaudio.com/forums/showthrea...921#post287921 ) I'm hoping you will this time.
Here's a cheap, easy to make and very good performing interconnect:
1. Get some 30AWG "Wirewrap wire". The one you want is made of silvered solid core copper with teflon coating. Here's an example http://www.elfa.se/elfa/produkter/no/178479.htm
Price is about 25 cents/meter
This cable you can also use as internal signal and power wiring in all line-level equipment.
2. Get your favourite RCA/XLR connectors (I use Neutrik's -very good and reasonably priced)
Price: RCA $2 a piece, XLR=$7.
3. Cut to length, twist with a hand-drill and solder your plugs (solder with some percentage of silver is recommended). I also use some Polyolefin heatshrink inside the plugs to make the strain relief effective.
So, there you are:
1m pair of RCA cables: ~$10
1m pair of XLR cables: ~$30
For those who are interested; the capacitance is about 20pF/m. If you desire a more rugged cable, you can thread the twisted pairs through some PTFE tube of suitable diameter.
Mads K
Old 15th February 2004, 05:44 PM   #2
Mad_K's Avatar
If you require a screened version, you can get some screened heatshrink tubing http://www.elfa.se/elfa/produkter/no/177861.htm
The finished cables:
Mads K
Old 15th February 2004, 05:48 PM   #3
Mad_K's Avatar
I sincerely hope some of you will try this one. My Nordost Solar Wind's are for sale if anyone's interested
A closeup:
Mads K
Old 15th February 2004, 05:58 PM   #4
cowanrg is offline cowanrg  United States
cowanrg's Avatar
Send a message via AIM to cowanrg
hum, i just see some connectors in the pictures, but where is the wire?
those are TINY.
Old 15th February 2004, 06:03 PM   #5
Mad_K's Avatar
Maybe you need some glasses
Yes they are thin, but also pretty tough because of the teflon coating. You want thin cables to achieve high bandwith.
I forgot to mention; it took me about 2 hours to make these two sets..
Mads K
Old 15th February 2004, 06:09 PM   #6
cowanrg's Avatar
hum, i knew someone who made some just like that, 20awg, silver coated copper, teflon insulated. they sounded so terrible. im not sure what happened.
Old 15th February 2004, 06:24 PM   #7
Mad_K's Avatar
Terrible you say? The cables I made sounds really nice, and they haven't even burned in yet. They do however sound a tiny little bit brighter than for example my GainWire (made the same way, but with 24AWG magnet wire and PTFE tubing). These are also a little clearer/more revealing. Maybe if you have a overly bright sounding system or equipment that should be masked by some cable-effects this one is not for you
edit: with my el cheapo/xbzls/balanced gainclone I prefered the GainWire-interconnects, but with the pacific/bzls/soz I think this one is much better. Haven't found a catchy name yet though
Mads K
Old 15th February 2004, 07:17 PM   #8
slowmotion is offline slowmotion  Norway
slowmotion's Avatar
Mad_K, all
I've done the same , using the same wire-wrap wire from Elfa,
the resulting cables sound pretty good, very open
I soldered mine directly to the amplifiers, no phono plugs.
Thanks for that , I wasn't sure
cheers,
- Jan -
Old 15th February 2004, 07:28 PM   #9
Mad_K's Avatar
-You're welcome. They where measured with a very expensive LCR meter at work, and showed 20-30pF depending on how tight it was twisted.
Glad you like it too; I'm getting a little ****ed when I think about that people feel they need to buy cables for thousands of dollars. (I'm also a little ****ed at myself -I used to be one of those people until I escaped from Audio Hell )
Mads K
Old 15th February 2004, 08:36 PM   #10
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
20 guage is too thick... i've used 33 guage with PVC from Radio Shack, the teflon is better (but more expensive). you can play with geometry a bit and get further improvements -- ie wrap the wire around teflon core from high end cable-vision wire (it is some work to remove the outer cover, braid & inner conductor).
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Cheap, simple and very good diy interconnectsHide this!Advertise here!
Rca Interconnects With Rg Cheap Cables juluska Everything Else 13 30th March 2011 06:31 PM
Cheap cable for DIY balanced interconnects? leadbelly Everything Else 4 15th April 2008 04:46 PM
Good switch for Stepped attentuater, Good cheap RCA jacks pjpoes Parts 20 10th March 2005 09:47 PM
know where i can order really cheap 1/4" interconnects? travis Instruments and Amps 4 8th October 2003 04:48 AM
Copyright ©1999-2017 diyAudio
