I am restoring a 1991 loudspeaker kit, and the original schematic is long gone.
One part of the tweeter crossover has a small value capacitor IN SERIES before a larger value capacitor.
I know that often -- to improve speed & transparency -- a smaller value cap is put IN PARALLEL with the larger value cap.
So, can you think of a reason why 2 SERIES caps would be in a tweeter X-over ? Or should the correct path be in PARALLEL.
Yes, I know --- not much info to go on.
I don't know what you have, but in pro audio, I have encountered "entry level" tweeters that came with a cap attached. I guess it was their guarantee no one would put full range through it. And if this speaker was more entry level, perhaps they took such a tweeter and simply connected it to their crossover as is, without removing the cap that came with it.
Is there nothing else connected to the tweeter or those capacitors?
OOOPS !!! I hit the post button too soon.
Let me finish this : the X-over I need as a schematic is for Joe D'Appolito's MTM ARIA-5s, in kit build, from around 1990. Elliot Zalyt at Zalytron sold them with the standard Focal inverted dome.
Focal woofers 5K013L [Kevlar] but I got the upgrade ACCUTON C-26 ceramic hard dome. I NEED A X-OVER SCHEMATIC FOR THE ACCUTON TWEET as part of the total speaker wiring.
- Design & Build
- Parts
- Crossover question -- Series caps / Parallel caps
