Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
How to suppress spikes on power supply
Old 14th February 2004, 12:34 PM   #1
kmt is offline kmt  Germany
Default How to suppress spikes on power supply
Hello to everyone!
I've a question concerning spikes on power supply: I've built up a headphone amp using a NE5532A and two BUF634. It works pretty good, very low noise etc. The only problem is the power supply. The PCB is powered by +/- 15V. For the power supply I used a toroidal transformer (30VA, +/- 15V) connected to a rectifier B40C3300. The +/- Va outputs of the rectifier are connected to 2 capacitors 1000µF.
I use 7815/7915 regulators to generate the voltages for the headphone amp. Inputs and outputs of these Vregs are connected to GND via a 100nF capacitor. Output is stabilized by a 220µF cap. The ripple voltage of the supply is very low, but I have switching spikes at the V+/V- when I turn on/off other electrical equipment (e.g. soldering station etc.)
My question is: what's the best/easiest way to suppress switching spikes on the power lines?
Any hints would be helpful
Greetz
Kai
Old 14th February 2004, 12:50 PM   #2
Pjotr is offline Pjotr
Pjotr's Avatar
Hi Kai,
For a headphone amp best is to use NOT a toroidal transformer but one that has inherently better PSU noise suppression. Use trannies with a U-shaped core and complete separated windings. These are available in Germany from Hahn transformers and Block. But Hahn is better quality IMHO.
You can start with a 250V VDR noise suppressor (“Transzorbs” and the like) across the mains if there is a lot of mains pollution. Use a big enough one of at least 25 mm diam. Ready-made spike and noise suppressors are available from a computer store.
Cheers
How to suppress spikes on power supplyHide this!Advertise here!
metal cone resonances, what direction, how to suppress? capslock Multi-Way 36 5th September 2013 06:36 AM
PFC voltage spikes tstitans Power Supplies 8 10th August 2009 06:34 PM
simplest way to suppress resonance peak ? percy Multi-Way 2 25th October 2006 04:29 PM
Ultra linear g2-anode suppress richwalters Tubes / Valves 3 30th November 2003 05:49 PM
heater supply (xformer specs are 6.3V 2.5A) as supply for a power LED? jarthel Tubes / Valves 10 21st July 2003 01:30 PM
