diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Parts (http://www.diyaudio.com/forums/parts/)
-   -   Making Game Lights for Brother (http://www.diyaudio.com/forums/parts/28061-game-lights-brother.html)
PHilgeman 12th February 2004 02:48 AM
I need to make a set of game-lights for my brother. It needs to be a thing where when one person presses their button, their light lights-up and also disables the other person's light from lighting, just as long as they didnt hit theirs first.
You get the idea.
What would be the easiest and cheapest way to do this. It is for a charity event, and I want to keep them well under their limited budget.
The only thing is they want 8 foot cords on the buttons, and then a light that is visible to the judge/host and optionaly visible to the audience.
-Paul Hilgeman
Da5id4Vz 12th February 2004 04:51 AM
2 Attachment(s)
This thing uses a pair of 4PDT relays that run around $8 a piece at radio shack.
The RESET button should be normally closed.
The PLAYER buttons should be normally open.
The extra contacts on each relay can be used to activate bells lights and judges indicators.
The concept is that a player button being pressed will cause the relay to activate and latch ON while simultaneously deactivating the other relay. Pressing the RESET button interupts power allowing the relay to unlatch.
I would recommend stuffing it in a project box with battery. I'm kind of tired so I wont go into too much more detail.
Da5id4Vz 12th February 2004 05:37 AM
This is a "mushroom" switch at Newark electronics. Its very big and can be pounded or slapped with the hand (and under $10) :
http://www.newark.com/NewarkWebComme...jsp?id=96F2984
This is the classic pendant switch that can be hand held ($22! they gotta be joking):
http://www.newark.com/NewarkWebComme...jsp?id=94F1652
If your budget is already blown, get some radio shack SPST NO push buttons and stuff them into bicycle handgrips.
The radio shack relay:
http://www.radioshack.com/product.as...5Fid=275%2D214
By running the relays off of a battery, the extra contacts on the relays can be used to switch at whatever voltage is required. Judges indicators could also be run off of battery while the last set of contacts could switch 120 VAC for on stage indicator lamps.
Da5id4Vz 12th February 2004 05:51 AM
And then there are the comercial systems:
http://www.groupics.com/index.htm
http://www.sandysowell.com/minigame.html
PC game mod:
http://images.google.com/imgres?imgu...UTF-8%26sa%3DN
PHilgeman 12th February 2004 11:59 AM
Awsome,
Thanks!
Da5id4Vz 12th February 2004 03:48 PM
Well its drawn a little funny, but I just rechecked it and I think it should work fine.
Sorry I drew the RESET as NO when it should be shown as NC, hope that doesnt cuase any confussion.
-Dave
Resources saved on this page: MySQL 18.75%
