Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
LM317 LM337 TO220 - thin metal tab
Old 5th September 2015, 08:46 AM   #1
HiFiNutNut is offline HiFiNutNut  Australia
Default LM317 LM337 TO220 - thin metal tab
I lately bought some LM317 and LM337, On Semi 1.5V from Digikey. The LM337 came with the "standard" metal tab, but the LM317 came with a very thin metal tab, so thin that my TO220 insulating washers won't work with it.
Since I could not mount them on the heatsink properly I thought I wasted my parts.
I then ordered them again, this time National Semi 1.5V from Farnell. It got worse. Both the LM337 and LM317 came with the very thin metal tab.
I started using LM317 and LM337 more than 10 years ago and have ordered them quite a few times. They all came with standard ones. But the last 2 times they came with very thin metal tab.
This forced me to examine the datasheet more carefully and I now understand that there are "single gauge" / thin metal tab of 0.51-0.61mm thickness and "dual gauge" of 1.41 - 1.61mm thickness.
But I just can't find how this information is available through the part numbers or through the part descriptions. This metal tab thickness is never listed as a parameter in Digikey's or Farnell's part descriptions.
Can you shed some lights? I now need to find out how to order the LM317 and LM337 with thick metal tab, or go and find the thin insulating washers.
Old 5th September 2015, 10:37 AM   #2
sangram is offline sangram  India
You could always use nylon screws or clamping bars if you wanted more or less mounting pressure and not have to worry about insulating the mounting hole...
I find a small piece of heatshrink tube and a standard flat nylon washer work just as well as a shoulder washer, along with some glue. Unfortunately this is rather a permanent assembly (including the bolt) and can only be used as a set hereon out.
Finally, if you are not dissipating much heat, heat transfer tape works quite well up to about half a watt and requires no extra hardware.
Old 5th September 2015, 10:52 AM   #3
abraxalito is offline abraxalito  United Kingdom
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
From TI's datasheet the -KCT suffix is the new thin (0.5mm) tab and -KCS the old, traditional 1.2mm thick version.
'The total potential here must be nothing less than astronomical.'
'Nothing less. The number 10 raised almost literally to the power of infinity.'
Old 5th September 2015, 11:33 AM   #4
Oh, of course, nylon screws would work. How didn't I think of it?
Old 5th September 2015, 11:35 AM   #5
Thanks for that. Interestingly, the National datasheet did not even mention it. I will probably find some nylon screws and if not look for the KCS.
Old 5th September 2015, 11:38 AM   #6
R.I.P.
Nylon.
Think about creep and particularly how creep is dependent on temperature.
Creep = change in dimension while under stress.
regards Andrew T.
Old 5th September 2015, 11:40 AM   #7
R.I.P.
I cut down the length of the top hat to suit the thickness to be secured.
A sharp knife slices through the thin collar very easily.
regards Andrew T.
Old 5th September 2015, 11:29 PM   #8
Enzo is offline Enzo  United States
agree^^^^
I often find the shoulder washers in my drawer are for a deeper hole than I have, so I poke it through the tab, and trim off the excess length with my Xacto knife.
Old 6th September 2015, 12:10 AM   #9
So nylon is not good because it is not suitable for higher temperature?
I have tried to cut the washer thinner but was not successful. I will try it again.
Old 6th September 2015, 12:52 AM   #10
jackinnj is offline jackinnj  United States
jackinnj's Avatar
TIP transistors now come with a thin metal tab.
If you are using a heat sink it shouldn't make a diff, but I haven't measured. I would imagine that the thicker tab absent a heatsink would have some thermal hysteresis.
LM317 LM337 TO220 - thin metal tabHide this!Advertise here!
Another look at the LM317 and LM337 regulators jbau Power Supplies 417 28th June 2017 02:43 AM
