Parts for Pultec style EQ (power transformers). - diyAudio
Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 2nd September 2015, 07:20 AM   #1
Default Parts for Pultec style EQ (power transformers).
Hi there,
I'm almost finished figuring out how to build and where to get all the parts for Gyraf version of Pultec EQ.
Now here is where I have my doubts: transformers.
Originally I wanted to use 2 toroids for power transformers, but I have done some reading and found out it is not the best choice for audio. A lot of people tend to recommend EI, C or R cores.
Basically, the advantage of toroids are higher efficiency, size and lower EMI.
Not sure if these advantages are relevant for me, because I was planning to put the transformers outside the enclosure anyways. Size is also not an issue.
It seems they are more vulnerable to mains noise, which would be bad.
But then again - does it matter? There is only 1 buffer, which adds no gain basically.
115-230V 30W high quality R Core Transformer 15V+15V with shield | eBay
So either 2 off the shelf toroids or 2 of these R cores.
What would you recommend? Maybe something else?
Lomo Kinap inductors filters for DIY eq project like Pultec bayanist Swap Meet 0 7th November 2014 12:27 PM
Cello Palette Style EQ Design (was High End Tone Control)... ThorstenL Analog Line Level 104 3rd December 2013 02:17 AM
Helios + Pultec tube EQ rack prototype. ruffrecords Tubes / Valves 11 28th August 2012 03:11 AM
HYPEX Parts F/S! HG Mono Power Supplies, Soft Start, TR501A Transformers! Socrates428 Swap Meet 0 27th April 2008 01:30 AM
Fake Parts - Catch 22 Chinese style mobyd Parts 4 7th March 2008 05:16 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright ©1999-2015 diyAudio
