Potentiometer with ON/OFF switch? - diyAudio
Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 23rd August 2015, 09:24 PM   #1
Default Potentiometer with ON/OFF switch?
I was wondering if anyone knows where I can get a push-pull dual gang potentiometer?
I'm building a compact stereo amp so I'm trying to keep the part's number down to a minimum, and I thought that turning the amp on and off by the volume knob would be a cool idea.
I did find this online: Dual Gang Potentiometer, Audio Taper, with Push Pull Switch DPST 1/4 inch X 7/8 inch Shaft
But I'm a little uneasy about purchasing off random sites
Has anyone come across these before?
Old 23rd August 2015, 09:36 PM   #2
rayma is offline rayma  United States
I'd avoid doing this if you can. It was routine in many older integrated amplifiers, but having 120VAC near
the audio is not a good idea. Also, the control wears out faster, and you can't use the very bottom
of the range, because the on/off function requires around 30 degrees of rotation. Good volume controls
just don't have this option.
Old 23rd August 2015, 09:37 PM   #3
I have used this supplyer for more than 10 years, never a problem.
https://www.tubesandmore.com/products/R-VS-1MA-SS
Old 23rd August 2015, 09:40 PM   #4
More common as far as I know is where ON is achieved by turning the pot
toward the right hand side, and OFF hard to the Left. The Quad 33
as a preamp used such a switch on the volume control pot.
If the 10k ohm range and its taper, and type suits then you have already
found what you need.
You can always arrange less current to the switch function by making
the pot switch activate a relay coil and the relay then do the heavier
duty of turning on, however would require some small current DC circuitry
that is ON before the switch activates
Try the large stockists like Mouser Farnell RS and Digikey
they will have many choices for you.
Cheers / Chris
Old 23rd August 2015, 09:55 PM   #5
I'm specifically looking for a dual pot
Unless there's some way of using a regular single pot as a stereo volume knob?
Old 23rd August 2015, 09:57 PM   #6
Besides wearing out faster, is there any sonic issue or health hazard with doing this?
Old 23rd August 2015, 11:26 PM   #7
"I'm specifically looking for a dual pot
volume knob?"
Look at all the pots on their site, you will find a dual with a switch in different resistance range.
Old 23rd August 2015, 11:30 PM   #8
I haven't found one with an on/off functionality on there. Any links would be appreciated
Old 24th August 2015, 05:23 PM   #9
try oldradioparts.com - will probably have to Email them
dual-gang audio with a switch is going to be tough. Mouser has discontinued carrying the Alpha line
Charles
Old 24th August 2015, 05:35 PM   #10
Mooly's Avatar
It can be done...but its not easy... you don't want to go there
Switched pots aren't the way to go in all this really. Use a separate mains on/off switch that's up to the job. Interrupting (switching) the current to a large power transformer can generate significant arcing at the switch contacts due to the large inductance of the primary winding.
Installing and using LTspice. From beginner to advanced.
TPA3116 with Potentiometer and switch combined aspaeth Class D 3 3rd April 2014 08:45 PM
Slide Switch & Potentiometer Replacement patknk939 Everything Else 6 7th October 2011 06:41 AM
Hall effect switch / potentiometer - Good for audio? FastEddy Parts 4 7th June 2007 03:09 PM
Potentiometer with switch? theAnonymous1 Parts 2 10th December 2006 07:08 PM
nice Co-axial rotary switch / potentiometer Puggie Parts 2 21st August 2006 02:49 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
