Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 9th February 2004, 07:46 AM   #1
tubenut is offline tubenut  South Africa
tubenut's Avatar
Default Bryston output and driver trannies, what are they?
A friend is looking at a 4B ST amplifier, one channel has gone down. This is his first Bryston, done plenty Krell and Cello and a whole load of European amplifiers.
Anyone know what SJ6521A, SJ6522A, SJE1490C and SJE1491C are when not labelled by Bryston?
Thanks all
Old 9th February 2004, 01:18 PM   #2
diyAudio Moderator Emeritus
roddyama's Avatar
Sorry this is not the answer your looking for, but why wouldn't your friend just send the amp back to Bryston? They absolutely stand behind their 20 year, fully transferable warranty, and if I'm mistaken, the ST modelscame out in the 90's. That should give him 10 years or more left on his warranty.
Rodd Yamashita
Old 9th February 2004, 03:06 PM   #3
Jan Dupont's Avatar
Send a message via MSN to Jan Dupont
Have you looked at this thread??
Building Bryston amps from the service manuals
Free Schematic and Service Manual downloads www.audio-circuit.dk, Company: www.dupont-audio.com, Joint venture: www.DupontMantra.com
Old 10th February 2004, 05:04 AM   #4
tubenut's Avatar
Default I and my friend are in SA.
My friend and I stay far from the US, he is an independant technician. He does repairs for several distributors and dealers down here.
Exactly why the Bryston has come to him we are not sure of but he is not likely to turn away his daily bread.......
Rgds
G
Old 10th February 2004, 06:15 AM   #5
Jan Dupont's Avatar
As I understand it, your fiend is doing this for money - Right???
If his costumer of some reason don't want to return his Bryston amp back to the factory for repair, your friend could ask him if he may use other parts for the repair.....
It should be easy to find substitute transistors just by looking at the voltage operation area and the Bryston frequency range.
If he's afraid of mismatch sound between the channels, he can change both channels.
Old 10th February 2004, 07:46 AM   #6
tubenut's Avatar
Default Yip...
That may well be what ends up happening I guess. The real thing would have just been nice for consistency.
Old 10th February 2004, 08:06 AM   #7
Jan Dupont's Avatar
As you can see, others have found substitutes from Motorola etc.
It's quite normal to use substitutes when components are either impossible to get or obsolete
Old 10th February 2004, 09:21 AM   #8
tubenut's Avatar
Default MJ15024/25 and MJE15030/31
My friend went through the substitute process and knowing that they are made by Motorola arrived at the above types. I also got a reply on audio asylum confirming that these are the business.
Krell also uses the same output trannies btw.
Thanks all
Will post just to let you all know when the amp is up and running.
Old 11th February 2004, 09:42 AM   #9
tubenut's Avatar
Default fixed, soaked for 20 hrs now. Thanks all
g
Old 11th February 2004, 10:19 AM   #10
Jan Dupont's Avatar
Glad to help
Thoughts on output PP trannies hurdy_gurdyman Tubes / Valves 20 26th January 2010 01:03 AM
preamp with output trannies. then_dude Tubes / Valves 6 13th October 2006 05:06 PM
output trannies flodge Planars & Exotics 4 21st August 2005 06:35 PM
Possibly fake Sanken output trannies (PIC) capslock Solid State 18 30th August 2003 02:42 PM
DIY Output Trannies smoking-amp Tubes / Valves 8 30th March 2003 07:29 PM
Page generated in 0.10018 seconds (77.89% PHP - 22.11% MySQL) with 10 queries
