caps for RIAA network - diyAudio
Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 8th February 2004, 09:53 PM   #1
GAK is offline GAK
Default caps for RIAA network
Hi
What kind of caps are best for RIAA network?
I need caps for tube based circuits.This means that caps must be 400 to 630V.
let's boom chitty boom
Old 8th February 2004, 10:48 PM   #2
diyAudio Senior Member
fdegrove's Avatar
Usually metallised polystyrenes or silvered micas are used.
Frank
Old 8th February 2004, 11:05 PM   #3
JonPike is offline JonPike  United States
Polyproplyne is good too.. probably the the best easily available type, since it seems polystyrene is going extinct.
You want close tolerances, at least 5%, if not 2% or better. If you're a pervert for perfection, try to match left and right channel values to as good as you can with a cap meter. (i.e. buy several and use the close pair) This may improve image reproduction.
Digikey has some 2% polyprop caps, though they may not be up to the tube level voltage rating you're looking for. Probably they do in the 5% range. Mouser is another parts supplier that has tons of parts and probably a few suitable choices.
Happy hunting!
designing RIAA circuit #2: optimal drive current for de-emphasis network Onvinyl Analogue Source 3 14th November 2007 04:22 PM
adding caps and snubber network to LM3875 power board quickshift Power Supplies 0 19th August 2005 02:12 PM
BHC T-Network caps Fiberbyte Parts 0 26th January 2005 10:48 AM
DNM T-Network Caps pinkmouse Parts 1 14th November 2004 03:41 PM
Copyright 1999-2017 diyAudio
