Vintage Oil Caps - diyAudio
Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 7th February 2004, 07:32 AM   #1
lpd is offline lpd  Canada
Default Vintage Oil Caps
I picked up a bag of used vintage "Mack" oil caps rated 600v and all different values ie. .01, .2, .5, ect. They physically seem ok, but I don't have a capacitor tester to test them. I hear oil caps generally last a very long time with minimal leakage.
Any opinions on these?
Old 7th February 2004, 07:58 AM   #2
You do have a capacitor tester, everyone with a battery does, charge one up using your... battery charger on 12volts or 6 volts, then short the connections with an insulated screwdriver, from a distance, if you see a spark, then that means at least some of it's charge is being held, which is usally a very good indication that the capacitor is allright...
Make sure you connect one wire to the charger, then tap one lead onto the other terminal, correct polarity only!!
Then turn off the battery charger and hold the screwdriver across the terminals...
If you don't see a spark then there must be a short somewhere inside the capacitor and the cap could be useless..
DO NOT touch the terminals at this time... or any time for that matter with your bare fingers or body.
I've found older and new PIO caps to be almost indestructable..
There is another method however...
Grab a cap and make sure it's discharged.. then set your analog multimeter to ohms and place the probes the correct way around, to charge the capacitor, then remove them and reverse the polarity, if the meter goes down then you have a discharging capacitor, if it stays on the righthand side of the display then you have a dead shorted capacitor.
Oh and using a raw 240volt source to charge or anything high voltage is asking for trouble.
I myself have 6 russian PIO caps from the 1970's and a couple from the 1940's all of them work as good as the day they were made...
Old 8th February 2004, 07:42 AM   #3
diyAudio Senior Member
fdegrove's Avatar
That true, which is why I'd rather invest in PIO caps for tube PSUs than electrolytics.
Check out ASC PIOs for larger values.
Another advantage of IO caps is that they have excellent damping capability.
Frank
Old 8th February 2004, 11:49 AM   #4
Account Disabled
I am one of those old farts that lived through days where all sizeable caps were oil caps and electrolytic was the new found God. We were urged to use electrolytics for their better sound, and how much oil caps sucked soundwise.
now, it is all upside down.
Is this thing more like fashion that cycles through every 10 years? or it is more of "anything rare and expensive must be good"? Has anyone tried to use air caps also? I got a couple of them in car battery size boxes for use in high-voltage transmission lines (12kv then). Would they be good for audio?
Old 8th February 2004, 12:54 PM   #5
Well they're certianly better for reliability! I would outfit an entire amp's power supply just upon that fact alone.
I'm not sure about the sounding of them as I haven't had my hands on a PIO decoupled-coupled amp as of yet.
I will however post my 'review' when and if I get my amp going which has 3 PIO caps per side in decoupling stages, I don't think it would make much of a difference in that job tho.
Other than that the four other caps in the amplifier design are 'Polyester'...
It would certianly be in my interest to replace those four with PIO and see how they go, soundwise.
Cheers.
Old 10th February 2004, 11:38 AM   #6
mcs is offline mcs  Denmark
Some caps may be indestructable - but not all. The Suzuki oil caps used in a lot of Japanese equipment (like my mother's Sansui) get very bad with age. They turn into resistors
I replaced a lot of caps in that Sansui to get it working...
Best regards,
Mikkel C. Simonsen
Old 10th February 2004, 11:58 AM   #7
Tube_Dude's Avatar
Yes!!...You are right!
See here in the forum...first all the people build the Pass designs...now the gainclones...what's next??
Me to!!!!
Jorge
Silver Mica caps VS Polystyrene caps KevinLee Parts 41 11th November 2015 03:38 PM
bypass caps for bypassing mylar caps? crippledchicken Multi-Way 4 27th February 2008 05:24 AM
Replacing multi-section caps with multiple caps? Sir Trefor Parts 1 29th May 2007 11:17 PM
Vintage speakers could they be voiced for electro-caps? Lorne Multi-Way 0 20th June 2005 10:45 AM
Replacing ceramic disc caps with silver mica caps? G Solid State 5 18th November 2002 02:02 PM
Copyright 1999-2017 diyAudio
