Are these Real? - diyAudio
Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 10th July 2015, 07:37 PM   #1
Sk8Ter is offline Sk8Ter  United States
Default Are these Real?
50 Chip Lot Texas Instruments NE5534AP Op Amp IC Chip | eBay
Thank you
Old 10th July 2015, 08:44 PM   #2
sofaspud's Avatar
More than likely, yes they are.
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine
Old 10th July 2015, 09:01 PM   #3
Pretty much impossible to fake at lower cost.
Only possible con is labelling 5534 as 5534A.
(The A version has lower input noise.)
rgds, sreten.
There is nothing more practical than a really good theory - Ludwig Boltzmann
When your only tool is a hammer, every problem looks like a nail - Abraham Maslow
Old 10th July 2015, 10:05 PM   #4
JonSnell Electronic's Avatar
Send a message via Skype™ to JonSnell Electronic
Look expensive though. Check out Mouser and RS first!
Support for Flying Mole, Allen & Heath, Valve amps, older designs & 2CVs. www.jonsnell.co.uk
Old 10th July 2015, 11:37 PM   #5
When comes to semiconductors, I am a little worry and tends to get from reputable places like Mouser, Digikey, Allied and Newark etc. You ain't going to test every single spec.
Hell, if I print the number of an expensive opamp onto a 741, as long as the frequency response is close, you are going to have a hell of a time to distinguish that until it's too late. You'll end up wasting time.
I only buy cheap resistor as it's so simple and you can't go too wrong. I don't even buy capacitors on ebay if I need higher voltages ones common in audio amps.
I just found the thread on Utsource. their stuffs are cheaper, but a lot of people have bad experience.
Old 10th July 2015, 11:52 PM   #6
kevinkr's Avatar
5534A DIPs are $0.84 each at Mouser in quantities of 10. I'd not run the risk on eBay, even at those low prices there is probably someone somewhere who figures it is worth counterfeiting for profit.
I regularly buy Russian mil spec surplus and sometimes generic resistors without issue on eBay, but I almost never buy semiconductors unless from a U.S or European vendor.
"Extraordinary claims require extraordinary evidence." - Carl Sagan
Old 11th July 2015, 02:05 AM   #7
nigelwright7557's Avatar
If in doubt sling them out.
RS and Farnell are the only people I will buy from.
They are usually pretty good on price anyway.
PCBCAD51 pcb design software. http://murtonpikesystems.azurewebsites.net/
Old 11th July 2015, 03:10 AM   #8
I am starting to like Mouser. They seems to be a little cheaper than Digikey. I just ordered two parts as a test run, we'll see how fast they ship. digikey always received in 3 days, nobody beat them so far from my experience.
AND Mouser take Paypal, I don't have to give out my credit card number.
Old 11th July 2015, 02:13 PM   #9
Default Thanks for the replys
Thanks guys for the reply's.....does anyone know how to read the nomenclature date codes etc on these chips...maybe that would be the key to knowing if they are real or not
Lawrence
Old 11th July 2015, 06:53 PM   #10
The pinout of a 5534 (unlike a 5532)
makes it hard to fake, i.e. relabel
something cheaper as a 5534.
rgds, sreten.
A Real Sub mikee12345 Multi-Way 10 10th March 2003 02:03 PM
Combing effects: How real in "real" rooms? smeade1079 Multi-Way 3 10th March 2003 12:32 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
