| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Hello
I am working on a project for uni, my group is making a passive infrared (PIR) light switch. We a using a PIR controller IC from a company called MOS, see link to data sheet below. Data sheet http://www.mos.co.za/pdf/data/m2008a.pdf On the schematic there is an inductor that is connected directly to the mains supply. The problem is that I dont know what type of inductor to purchase, I am assuming that it would have to be some sort of mains rated type like you get for capacitors. Could someone tell me if there is a certain type I would have to use and what it should be, whatever it is i hope RS stocks them. This is the circuit schematic we are using. http://www.mos.co.za/pdf/apps/m2008a...3_smd2_sch.pdf Thanks for any help you can give Mark. |
#2 |
Mark,
It's just a choke to reduce conducted mains interference. You can use a 220 uH choke from RS as shown below. Acc to their website, it is on stock. If you need to switch more than 3A load, select another one from this series; the value is not that important. Steven |
#3 |
Thanks Steven and Magura who emaild me.
I will consider both your suggestions. Thankyou Mark. |
| diy inductors | speedie | Parts | 23 | 21st October 2009 12:02 AM |
| inductors | tonysherwin | Multi-Way | 3 | 7th May 2008 10:00 PM |
| Inductors | tumler | Solid State | 4 | 16th August 2006 06:31 AM |
| Inductors in T Amp | @lf | Class D | 55 | 21st November 2005 10:16 PM |
| Anyone tried these inductors? | blank527 | Pass Labs | 9 | 9th January 2003 02:16 PM |
| Page generated in 0.07963 seconds (65.07% PHP - 34.93% MySQL) with 11 queries |
