Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
1/4" headphone jacks
Old 15th June 2015, 10:15 PM   #1
62vauxhall is offline 62vauxhall  Canada
Default 1/4" headphone jacks
I recently bought a fixer upper preamp with seemingly few problems. One deficiency though is a broken headphone jack and it is not repairable. For a replacement, I am wondering if I can use one from a tape deck. They both have 3 leads connected to them but will they function the same? By that I mean will the jack from the tape deck have the ability to mute the pre amp's output once a headphone plug is inserted?
Old 15th June 2015, 11:33 PM   #2
rayma is online now rayma  United States
There are different versions, some with, and some without, the switching function.
Look carefully at the construction of the jacks behind the panels to see if they are built the same way.
Old 16th June 2015, 12:40 AM   #3
It would be hard to tell that. The broken one went to pieces and the pieces are long gone and the intact one is encased in plastic. If there are variants, I suppose the only was to see is connecting the good one. I can hook it up using jumpers when I get home and see what happens when I stick in the plug.
Old 16th June 2015, 03:14 AM   #4
Well that would have been too convenient. Just tried the ex-tape deck jack and it does not shut off signal to the main pre-outs. So, will be visiting the two local parts stores to see if they have something that fits the bill.
1/4" headphone jacksHide this!Advertise here!
Switch Box (jacks 1/4") mfspdesigns Vendor's Bazaar 0 24th March 2014 02:17 PM
1/4" input not working using RCA jacks? dinkyguitar Solid State 7 30th July 2012 12:12 AM
Can I use 1/4" jacks for speaker connectors? MikeHunt79 Everything Else 48 5th December 2007 11:25 AM
Source for decent quality headphone jacks theatrus Headphone Systems 7 20th February 2004 11:17 AM
1/4" vs rca jacks AJ Bertelson Pass Labs 10 16th March 2003 05:08 PM
