MUR860 rectifying bridge question
Would the MUR860's be able to rectify a 300VA 2x24VAC toroid in a dual rectifying bridge setup? Would it need cooling? The MUR860's have an IF(AV) of 8A, and the toroid will give (150/24=) 6,25A per secondary.
What do you think?
It is going to be used in a subwoofer-amp with linkwitz transform circuit, so I think the bridges will have plenty to do (because of the extra gain at lower freqencies) ;)
Parallel operation .
This is probably a silly question.
The MUR1660CT and MUR3020PT have their anodes tied together. Can they be used in parallel ?
To make a bridge they will need a device with cathodes connected together. I can't find such a device in this range.
Otherwise they have to be used in parallel !
Have I overlooked something ?
Thanks.
peranders said:
The be short: Just tie the two anodes together, then you will have the diodes in parallel.
The two diodes will have slightly different turn-off characteristics, even when they are in the same package. By parallelling these, you may be removing a little of the advantages gained by the use of soft recovery types. The two diodes will switch off at different times, thus prolonging the noise generated.
The use of a single diode with higher current capability would be better.
James
Please remember the application (subwoofer). I don't think any swiching garbage will be heard when used <100Hz. In other words, go parallell if you must. Or, even better, use a standard rectifier bridge4 good for at least 25A, it should be cheaper.
/Niclas
