Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Transformer Voltage
Transformer Voltage
Old 4th February 2004, 12:46 AM   #1
dswiston is offline dswiston  United States
Default Transformer Voltage
Hey all. I'm working on a project of Rod Elliots, the new mosfet amp to be exact. Anyhow, I ordered a Basler transformer from apexjr and forgot to look and see if it was center tapped. Well its not but it has dual 50v outputs. So I put 'em in series to get a 50-0-50 output. However this results in about 70v across the filter caps. Now for the high power version of the project a +-70v is ok. However, I am making the "lower" power version and it looks like I'll have some problems with power dissipation. According to the specs, +-56v is the safe max for the low power version. So I would like to know if anyone has some simple ideas for how to cut the voltage down. The transformer has dual 50V taps, and from what else i can tell and for what its worth it has 10V, 20V, and 6.3V taps which look like they handle significantly less power than the 50v taps.
Thanks guys.
BTW, first post, yaya me!
Old 4th February 2004, 04:35 PM   #2
officeboy is offline officeboy  United States
Send a message via MSN to officeboy
dual 50v outputs is quite a bit the same as dual center tap, think of it as a 50-0-0-50.
The problem is that you are going to get 70V pretty much all the time. After rectification, your voltage goes up by about 40% (aka multiply original voltage by 1.414) That means your 50V is going to be 70V using full bridge rectification.
You might be able to unwind some of the secondary coils to lower the voltage a bit. Shoot for around 35V AC at the transformer to get 50V DC after
The below copy/paste is an excerpt from http://sound.westhost.com/project101.htm
Code:
AC Volts DC Volts VA Power (8 ohms)
20-0-20 +/-28V 100 40
25-0-25 +/-35V 100 50
30-0-20 +/-42 160 80
40-0-40 +/-56V 200 150
50-0-50 +/-70V 300 240
Transformer VoltageHide this!Advertise here!
Sec. Transformer Voltage for Aleph 5 Zapped Pass Labs 10 7th December 2003 07:33 AM
Power Transformer Voltage trustalbini Tubes / Valves 7 11th May 2003 01:37 AM
Rail voltage compared to transformer voltage SteveG Solid State 4 23rd July 2002 12:50 AM
