Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
DIY attenuator (was silver wireing)
Old 2nd February 2004, 07:00 PM   #1
Magura is offline Magura  Denmark
Magura's Avatar
Default DIY attenuator (was silver wireing)
Better stay clear of threadjacking
Originally posted by fdegrove
Well from what I hear there are much better ones around.
Did you check out the ones by ShallCo, Seiden or Blore Edwards?
They won't be cheap in small quantities but you'll also have the possibility of ging beyond 23 useable steps if needed.
Thanks for the names...any particular well working switch from those you mentioned?
The price dosnt matter (thought id never say that)....
All im looking for is something to copy/- refine.
How many steps would be usefull? (must be able to divide the number by 1.8 since the stepmotor likes that number)
Cheers
Magura
Everything is possible....to do the impossible just takes a little while longer.
www.class-a-labs.com
Old 18th March 2004, 11:13 PM   #2
Magura's Avatar
Progress:
Made the mold for the silver contacts yesterday, im gonna cold forge them in order to get reasonable hardness.
The number of positions have been determined to be 40. That should sound like something close to a potentiometer, right??
Should the slider be fine silver as well or would beryllium copper be better?
Magura
Old 18th March 2004, 11:42 PM   #3
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
DIY attenuator (was silver wireing) Send a message via AIM to Peter Daniel
You might like this pic. It is custom switch made by Cello.
Old 18th March 2004, 11:44 PM   #4
And here's a technical description:
Old 19th March 2004, 12:18 AM   #5
Magura's Avatar
Thanks Peter.
Any chance to get an "upskirts" photo of the switch?
Ive opted for ceramic bearings/-axle. They are less sensitive to dust and so forth....and readily available (since i have no chance to machine AlN), and even for free, wich makes them sooo interesting
Magura
Old 19th March 2004, 12:53 AM   #6
Unfortunately that was the only available photo.
Old 19th March 2004, 01:58 AM   #7
bigparsnip is offline bigparsnip  United Kingdom
bigparsnip's Avatar
I know this will probably only make me want to cry (I'm so jealous), but how much did (do?) those things go for?
Old 19th March 2004, 02:05 AM   #8
Magura's Avatar
Machined to bearing specs. 1 axle and 2 bearings is around 100 euros.
If you ask me.....thats a scaaary number for that
I get ones that are rejected for one or another reason, like a chip in the face of the bearing or the like, wich makes no difference for this purpose, as long as the radial raceways are fine.
They are nice to use since the thermal elongation of AlN is close to zero and they dont need any maintainance or lubrication =very clean.
Magura
DIY attenuator (was silver wireing)Hide this!Advertise here!
Help with some speaker wireing please.... Minion Multi-Way 5 7th December 2008 01:01 AM
Please Help With Wireing My Cab!!! Dtorre Instruments and Amps 5 19th July 2007 09:27 AM
Shielded cable for internal amp wireing: where do I connect the shield? Bricolo Parts 11 26th June 2003 01:26 AM
Help with Tranny Wireing. jleaman Solid State 7 28th January 2003 04:51 AM
Atx computer powersupply Wireing schematic jleaman Digital Source 8 15th August 2002 09:59 PM
Copyright ©1999-2017 diyAudio
