2.54mm pitch IDC connector not requiring expensive crimper/tool? - diyAudio
Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 23rd March 2015, 10:04 PM   #1
autopoiesis's Avatar
Question 2.54mm pitch IDC connector not requiring expensive crimper/tool?
I'm refurbishing a 16-ch mixing desk with 2x4-ch expansion units, which are attached with the illustrated IDC connectors; unfortunately he main loom on the main desk side got yanked out (probably 20 years ago)
The female headers need replacing, and I'll need to reconstruct the looms on the expander side to make up the lost length (and replace one section that's AWOL).
Pin spacing 2.54 mm; pin thickness 0.65mm (square). Marked 'Panduit' but they don't appear to make these any more.
There's a bewildering selection of IDC connectors available but most seem to be either multi-row, for ribbon cables, and/or require a really expensive crimping tool.
I thought it would be easy but I'm lost!
Can anyone recommend a single-row 2.54mm connector, for discrete wires, that requires at most a cheapish punchdown tool?
Best wishes,
AP
Dogs have masters; cats have staff
Old 24th March 2015, 02:01 AM   #2
The hand punch-down tool for the "MAS-CON" connectors is a Panduit MRT-100F, the handgun tool is the MCT with the CTD-100F head. I have both plus lots of the connectors. PM me with details and maybe I can help.
AMP had the MTA series connectors, the tools are not interchangeable though. E
Old 25th March 2015, 09:11 PM   #3
mickeymoose really helped me out here identifying the series, and tool. Wish I'd asked earlier!
Current part numbers for Studiomaster Mixdown Classic 2.54mm pitch internal loom IDC connectors is
Manufacturer:Pancon
Range: MAS-CON® .100" IDC Wire to Board Connector System
Part numbers (for AWG 24, gauge used in original desk)
CT100F24-12 (for the 12-pin loom)
CT100F24-14 (14-pin )
Hardly anyone stocks either of them, and no-one has both - I spoke to Pancon and the larger pin counts (>8?) seem not to be current production - unless you want 2500+ ...
So, if repairing, make up from 2x6, or 2x7 or other smaller, stocked connectors. CE (End) series could be used at loom ends; these seem easier to get than CT (Through).
Pancon Products - IDC Female Sockets
Stock check link: CT100F24 Inventory, Pricing, Datasheets | ECIA
Hope this is helpful to someone one day!
Old 26th March 2015, 12:57 AM   #4
dangus is offline dangus  Canada
It's sometimes feasible to make a punchdown tool by grinding and cutting a spare screwdriver.
crimping tool crimper fakeout Equipment & Tools 16 21st August 2012 12:26 PM
European IDC connectors BudP Parts 6 9th July 2010 04:42 AM
Insulated terminal crimper 454Casull Parts 1 31st May 2009 10:28 PM
Lead bender/crimper d3imlay Parts 0 19th January 2007 02:29 AM
driver distance requiring shielding timsch75 Multi-Way 3 3rd August 2003 06:13 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright ©1999-2015 diyAudio
