changing a power supply inductor - diyAudio
Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 11th March 2015, 11:23 PM   #1
WaFfLe is offline WaFfLe  United States
Default changing a power supply inductor
the current project im working on has a bad inductor, i know this is mainly to suppress the mains noise. when replacing inductors like these, what value should i pay attention to for the replacement unit? (assuming i cannot locate the exact original part)
* rated AC current A
* inductance mH
* dc resistance Ω
* temperature rise K
i guess my question is, what values can be fudged and still work or work better than the original?
similar to the known fact that you can go higher voltage rating on caps...
Old 12th March 2015, 03:34 AM   #2
opcom is offline opcom  United States
Pretty much all the values can be fudged quite a bit. Is the original missing or burned up? I checked a small one like it before and it was 110uH on each coil, resistance <1 Ohm. Anyway, AC amps is important, and maybe 50-200uH is OK. They shouldn't get hot, so rise is not important. Ohms low..
Old 12th March 2015, 04:27 AM   #3
I was wondering if I could up a certain value to lower the mains noise that is audible when running
Old 12th March 2015, 04:28 AM   #4
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via MSN to abraxalito Send a message via Yahoo to abraxalito Send a message via Skype™ to abraxalito
DC resistance would be the main concern, you can go lower but not higher (it might overheat). Also this is a segmented winding CM choke - most CM chokes aren't segmented. Segmented provides lower self-capacitance and hence better rejection of noise.
When irony first makes itself known in a young man's life, it can be like his first experience of getting drunk - Robertson Davies
Inductor for magnet power supply dwlee6vn Power Supplies 26 14th March 2013 01:06 PM
Help with inductor choice in power supply jmillerdoc Solid State 1 24th February 2011 12:03 PM
Which inductor for IC power supply decoupling Banfi T. Parts 1 17th January 2010 07:11 PM
2.2mH inductor in Aleph3 Power supply vsr123 Pass Labs 10 9th April 2003 02:04 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
