| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
hi there, im hoping to convert a small mackie mixer and hopefully a focusrite voice channel to run on 12v dc... dont really want to lug about an inverter, so i was wondering if anyone had tryed bypassing the transformer stage, and connected straight to the 12v rail? Does a voice channel even have a 12 v rail?! excuse my ignorance, new to this game!
Would be good though: location recording, with quality audio gear ontop of a mountain, with a lead acid block battery, and not spending every penny i own on an expensive film mixing desk! ( i guess phantom powering would be a problem?) thanks. gog |
#2 |
Most of this gear uses internal positive AND negative supplies up to 15V or so, therefore direct powering from 12V would not be possible. An inverter could be designed to convert 12V direct to the voltages needed, however this would be a custom design and involve modifications to the units involved.
Think external inverter is best bet. Cheers |
#3 |
what would it involve to fit an inverter to go from 12 v dc to say 15 v dc? is this a phisically large bit of circuitry, or could it fit inside the existing casing?
what would happen if you did run something on 12 v if it was meant to be run on 15???? sorry- being a dullard! thanks for the advice! |
#4 |
Probably only consequence of running 15V gear on 12V is lowered headroom, HOWEVER you still need a NEGATIVE supply line - so therefore inverter still needed.
Would think circuitry involved would be too large for internal fitting. Cheers |
#5 |
http://sound.westhost.com/project69.htm
this would provide + and - 12V, which as Centauri says might work with reduced headroom. How small is your mixer, though - have you tried sticking an ampmeter in series with the supply rail? Rod's circuit is good for up to 40mA. |
#6 |
The simple answer is most of your gear would run fine on
a split 12-0-12 volt supply but you need two batteries. A small inverter is going to be a lot less heavy than the extra battery required but then again supply noise is a viable issue. A specialised battery pack is another option. Also if using car batteries nominal voltage = 13.8V. Extra supply voltages beyond those for the op-amps would not be available. |
| What advantages running ported midbass if you are running a sub? | mitchyz250f | Multi-Way | 3 | 20th May 2008 02:34 PM |
| FS: Various Lab. Equipment | Bakmeel | Swap Meet | 1 | 14th July 2004 10:58 AM |
| Balanced Mic Preamp, Transistors...and Studio Equipment | iCebReakEr409 | Solid State | 4 | 28th December 2003 08:03 AM |
| Recording Studio Equipment | johnferrier | Solid State | 11 | 24th November 2003 08:39 PM |
| Page generated in 0.08597 seconds (80.16% PHP - 19.84% MySQL) with 10 queries |
