I'm assuming (for no good reason) that you are running this amp on 12 volts.
The voltage rating of the caps needs to equal the supply plus a bit more for safety. What supply will this be running on ? I see you have 10 and 6.3 volt caps on your list.
I hope to run with 3,3V. The amp can have 1,8 - 5,5V.
For those supplies the parts are fine... as long as you know how small they are.
I daren't even ask... how are you going to build this ?
Yeah i know how small they are. I will use a microscope and buy many of each. I build until i manage to make one that works lol. I only need one for my first prototype. My hand is also where steady so i think i can do it.
OK. Well good luck... and post some pictures of it when its done
Thank you i will need it! I will sure post some pictures. Thank you so so so much for your help!
Looks basically OK.
Pin 4, the input should be as in your earlier post #1. The audio is AC coupled via the 22k. Not grounded via a 22k
Pin 1. Normal operation is with it grounded ? It probably is but worth just checking the data sheet to be sure.
Oki thank you changed the Pin 4 and removed ground. Pin 1 is not something i'm going to use so i grounded it.
This is how Pin #1 looks in the data sheet.
I haven't just time to look at the data sheet now. What its showing is that pin 1 responds to a voltage input. That will mean the chip will be in sleep mode when its either high or low... so you need to check and wire pin 1 to either the positive supply or ground as appropriate for it to work. Or... it may be normal to leave it floating. Look for examples in the data sheet and/or pin descriptions and what the voltage needs to be so that its not sleeping.
Edit... if your stuck I'll have a look tomorrow
Okay i found this:
I think this is equation to calculate it.
That's it. So it needs to be tied high to the positive supply to be active.
This looks right?
I can't find a 8uF Resistor that is surface mount. Can i use others? Like 8.06uF.
An 8 uF resistor or an 8 ohm capacitor
Do you mean R4 that's marked '8' ? If so then that is the speaker itself (which is nominally 8ohm).
- Design & Build
- Parts
- Picking out parts for this schematic
