Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 27th January 2004, 04:44 PM   #1
Default Are the electrics safe in my studio?
I have a small studio and I share it with someone else. We are worried that the elecetrics might now be safe because we're overpowering them.
Can anyone tell me what is the maximum wattage you can suck out of one plug socket before it gets dangerous? And what are the dangers?
Cheers
All the fun of
www.thefair.de
Old 27th January 2004, 04:57 PM   #2
Jax is offline Jax  Sweden
I see you live in EU. Wall outlets are usually fused at 10A but I would not pull more than 6A continuously.
The danger is fire from bad connections, usually the screw in the plug. Make sure the cable ends are not tinned in the plug.
Jan
Old 27th January 2004, 07:05 PM   #3
okay, thanks. So you don't think it's worth worrying about, essentially?
Someone else told me not to worry unless I was running a huge light show in there! I really have no idea about these things.
All the fun of
www.thefair.de
Old 27th January 2004, 10:32 PM   #4
230V 6A is around 1300W so it should be enough without a lightshow
You can feel the cords, if they become very warm then you are at the limit.
Jan
Old 28th January 2004, 06:00 AM   #5
It's not neccessarily the cords to your kit that will get warm. The connections inside the wall socket or other internal wiring can get warm and cause fires if the circuit is overloaded.
Having said that pulling 6 or even 10 amps from a socket should be safe, all things permitting. If in doubt, speak to an electritian, they should be able to check that all is well.
Need help with car electrics Jonny Hotnuts The Lounge 7 23rd September 2008 02:48 PM
DIY ESL electrics questions volvoman62 Planars & Exotics 4 22nd August 2008 04:55 PM
Is it safe???? mikee55 Solid State 4 31st August 2006 10:17 AM
Hakko 936 - ESD safe vs. non-ESD safe KT Parts 2 20th June 2004 03:58 AM
Page generated in 0.08432 seconds (75.77% PHP - 24.23% MySQL) with 10 queries
