Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
LM6172 oscillating
LM6172 oscillating
Old 27th January 2004, 08:35 AM   #11
Saurav is offline Saurav
Hmm... that's going to be tight - I looked at my layout, and it'll be relatively easy to do for one channel, but quite a bit harder for the other.
Things are looking better now. I added a feedback resistor to the inverting input and another resistor from there to ground. Put a cap across teh feedback resistor. Turned out to be too big, killed teh treble (this is the one cap in my stash that I don't know the value for), I'll pick up appropriate caps tomorrow I think. Anyway, those reduced the oscillations but didn't eliminate it. Finally I used another suggestion from the app note (which the kit instructions also had) and increased the input series before the first preamp to 2K ohms. Apparently this reduces the overall slew rate of the system. Anyway, that took care of pretty much all the oscillation. The output is still kinda fuzzy, but I'm down on the lowest setting on the voltage and the timebase on my scope, so I can't reliably make any judgement calls any more.
I can't hear any high pitched squeal from the speakers (I can if I remove the caps, but it's very low, and the scope shows a little oscillation with the cap removed). So right now I have the cap out, I'll put in caps of the correct size tomorrow.
Old 27th January 2004, 02:56 PM   #12
I shouldn't post after midnight. Did I get that right? This cap should form a low pass filter, so to push the corner frequency up higher, I'll need to reduce the value of the cap. Correct?
LM6172 oscillatingHide this!Advertise here!
WTB: Lm6172 Dip AR_sound Swap Meet 0 19th October 2006 03:05 AM
Wtb: Lm6172 & 6171 pablosapiens Swap Meet 2 22nd January 2006 06:21 PM
LM6172 sound jesper Solid State 1 24th December 2005 05:17 PM
Modify LM6172 for 12V justpoor Digital Source 5 11th September 2005 06:30 PM
lm6172 class a bias? crippledchicken Parts 0 3rd September 2004 05:33 AM
