Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 26th January 2004, 09:35 PM   #11
diyAudio Moderator Emeritus
jean-paul's Avatar
They could have left out the opamps too ... I know X-pre and that one uses a opamp and a tube too. Weird if you ask me.
It's only audio
Old 26th January 2004, 09:41 PM   #12
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
Originally posted by sobazz
... that cannot be! Simply not possible! They could at least have chosen RK17!
I wouldn't assume anything at this point. I've heard Nagra is using cheap pot in their $6k preamp because it simply sounds better than anything else they tried. I also had some cheap Alps (different style though) and they sounded better than Black Beauty.
Old 26th January 2004, 09:56 PM   #13
sobazz is offline sobazz  Denmark
sobazz's Avatar
"Sound better"... I objected to the use of RK09 only due to tracking imperfertions... and tracking imperfections - I guess - is a great deal of the reason why people bother buy RK27 or RK40 (maybe even RK50).
Regarding sound quality.. you can always use a series resistor and a cheap pot for shunting a part of the signal to ground. I suppose we agree that it would be the optimal pot configuration, since no questionable pot is present directly in the signal path, thus you can easily use a cheap pot if configured correctly. But the tracking issue is still present...
Old 26th January 2004, 10:11 PM   #14
Surprisingly it may sound, but the shunting part is also very influential on the sound. As to the matching problems, you can always get more of those cheap pots and do matching yourself.
Source for Alps RK16 RK163 Pots??? Zero Cool Everything Else 0 6th March 2008 01:01 PM
Potentiometers BlairHatcher Chip Amps 22 9th February 2005 12:24 AM
Fake Alps potentiometers chalky Parts 2 20th December 2004 02:39 PM
Potentiometers slogan2112 Solid State 2 19th December 2003 06:54 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
