33000uF 63V capacitor - diyAudio
Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 18th January 2015, 08:28 AM   #1
Default 33000uF 63V capacitor
I am looking for 33000uF 63V big cap. I found in Digikey 382LX333M063N102 Cornell Dubilier Electronics (CDE) | 382LX333M063N102-ND | DigiKey
It's only $17!!! What is the catch?
Old 18th January 2015, 10:44 AM   #2
How much would you like it to be?
Old 18th January 2015, 11:18 AM   #3
irribeo is offline irribeo  Netherlands
Obviously $850 for one capacitor is a bit much, that might be the catch
Old 18th January 2015, 11:35 AM   #4
Mark Whitney's Avatar
They expect you to order 50 pieces. Now that would make a big power supply.
Regards Mark.
Old 18th January 2015, 12:37 PM   #5
Hikari1 is offline Hikari1  United States
http://www.apexjr.com/images/Nippon50v33000uf.jpg
$3.95 from apex jr. I am using 6 of them in my amp's psu. 50V though, might work for you?
Old 18th January 2015, 12:55 PM   #6
Almost 12A of ripple current capability. That's very good for a normal commercial grade capacitor.
Three paralleled 10mF 63V Cornell will easily beat that.
regards Andrew T.
Old 18th January 2015, 04:58 PM   #7
So that is a good cap? The reason I asked is because I saw on ebay that the same value caps are generally a lot more. The only gripe is it has a solder terminal rather than the conventional screw terminal.
What is ripple current means? Should I choose higher value or lower value?
Old 18th January 2015, 05:37 PM   #8
infinia is offline infinia  United States
infinia's Avatar
those look like really great caps I like the aspect ratio, close terminal spacing is usually a good sign > esr at higher frequencies.
like four million tons of hydrogen exploding on the sun
like the whisper of the termites building castles in the dust
Old 18th January 2015, 06:04 PM   #9
rayma is offline rayma  United States
382LX333M063N102 Cornell Dubilier Electronics (CDE) | 382LX333M063N102-ND | DigiKey It's only $17!!! What is the catch?
The catch is they're not in stock.
Old 18th January 2015, 06:07 PM   #10
Ripple current is the filter capacitor rms current, which if excessive causes heating and a shorter life.
FS: RIFA PEH169 33000uF Capacitors 63V [With picture] Sander Swap Meet 2 6th March 2012 12:00 PM
WTB: RIFA PEH169 33000uF/63V x2 reaction Swap Meet 0 12th December 2011 11:48 AM
Kendeil 63v 33000uf audio capacitors for sale!!! umut1001 Swap Meet 0 29th June 2010 01:50 AM
WTB:RIFA 33000uf 63v capacitors paulyang Swap Meet 2 6th December 2005 06:41 PM
FS: RIFA 33000uF Capacitors 63V [With picture] Sander Swap Meet 12 9th November 2005 01:58 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
