Need help - sourcing "petite" electrolytic capacitors - diyAudio
Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 17th January 2015, 11:03 PM   #1
Mayank is offline Mayank  United States
Mayank's Avatar
Default Need help - sourcing "petite" electrolytic capacitors
Hi:
I need to replace the 4 electrolytic capacitors in the PSU of a Hafler 9300 supernova amp.
The originals are screw type 15,000uF/75V which are just 2.0" high & 2.5" diameter. Screw holes are 30mm apart. These were 86DY series probably a special order by Sprague for Hafler in the 90s.
I've checked the usual sources - Mouser, Digikey & Newark, Unfortunately, none of them have any similar replacements in that petite 2.0" height.
Anyone can help locate a source for these?
Mayank
Old 17th January 2015, 11:37 PM   #2
Richard Ellis's Avatar
Location: Mar del Plata, a BIG seasonal getaway city, can see the Ocean from our residence.
While not an exacting match...I would love to see somebody put to use some of these. Your looking at 4400uF@ 125 V
__________________________________________________ _Rick........
Old 17th January 2015, 11:49 PM   #3
tomchr is offline tomchr  United States
tomchr's Avatar
While not ideal, can you find a snap-in type and make that work?
~Tom
Modulus-86: Composite amp achieving 0.00018 % THD. Damn Good 300B, Novar Spud, 21st Century Maida Reg., Filament Reg., etc.
Neurochrome : : Audio - http://www.neurochrome.com/audio - Engineering : : Done : : Right
Old 17th January 2015, 11:53 PM   #4
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via MSN to abraxalito Send a message via Yahoo to abraxalito Send a message via Skype™ to abraxalito
I'd suggest replacing the set of 4 with an array of snap-in types mounted on some perfboard. Nichicon has 4700uF/80V 25*50mm - LLS1K472MELA Nichicon | Mouser
Given all the extra caps you could even introduce some series inductors to clean up the ripple.
"Having people devoted to attacking you even in unfair, invalid or personal ways is actually valuable for keeping one honest and self-reflective." - Glenn Greenwald
Old 17th January 2015, 11:56 PM   #5
Mayank's Avatar
I could try make that work - with perhaps a "sandwich board" with a screw soldered, as the original PCB is double sided
But, I wasn't successful in even locating snap-in types in that short 52mm (2") height.
Rgds
Mayank
Old 18th January 2015, 03:56 AM   #6
Mayank's Avatar
Thanks.
That is probably the only workable solution. I can get 16 x 3,900uF/80V capacitors and mount 4 each in parallel on a perf-board.
Rgds
Mayank
Roederstein 'BAKELITE' series EK capacitors - "Living Legend" OR "Looney Legacy" ...? The Space Egg Corp Parts 69 6th November 2014 08:29 PM
A new "King Of The Hill" electrolytic? KBK Parts 1 8th January 2007 04:34 PM
What does "up" mean on Electrolytic Cap? lgreen Parts 31 6th June 2006 09:45 PM
Is "reforming" Electrolytic Capacitors necessary? gwyz Tubes / Valves 16 8th November 2005 06:35 PM
Continental Capacitors' "Type-A" oil-filled capacitors? radical Parts 0 21st October 2004 09:39 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
