Looking for good dual LOG. POT. but 1kOHM - diyAudio
Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 16th January 2015, 01:13 PM   #1
Piotr is offline Piotr  Poland
Piotr's Avatar
Default Looking for good dual LOG. POT. but 1kOHM
Hi! It seems that they are produced in 10k or bigger values. I'm looking 1k or 2k at least. Stereo logarithmic version. Does anybody know where I can get one?
Old 16th January 2015, 02:17 PM   #2
I have never seen a log pot < 10KR
However, log pots are simply made with two sections of track with different resistances. This gives a surprisingly good approximation to a log taper, but with matching difficulties between channels.
It is very easy to simulate a log pot using some fixed resistors. Example:
http://electro-music.com/forum/phpbb...er_amz_168.pdf
Cliff
Old 16th January 2015, 02:37 PM   #3
forr is offline forr  France
forr's Avatar
Here are some, it's a cheap brand :
MONO
4mm Potis, mono bei reichelt elektronik
STEREO
4mm Potis, stereo bei reichelt elektronik
It seems that loading cursors by low impedances may be detrimental to their life length.
Old 16th January 2015, 02:50 PM   #4
Piotr's Avatar
Thanks,
I saw 5k ALPS RK27, but this is still too much resistance.
Current load should not be an issue because power is still dependent on voltage level you are using.
Yes, stepped attenuator should be fine. I actually have got some experience, I've made z-foil series ladder last year but it's 20kohm.
For 1k ladder resistor's resistance range should be like.. about 2 - 300ohm.
Maybe some wirewound resistors could be good? Or maybe some metal film like PRP? I think z-foils are not that necessary in this app. What do you think?
Anti-log pot versus log pots carlmart Chip Amps 12 25th July 2014 01:25 PM
WTB: 10k dual gang log pot. (A) maurycy Swap Meet 4 9th February 2011 02:57 PM
WTB: 50k Lin 20k Log Dual Pot thousandshirts Swap Meet 1 16th September 2008 05:35 AM
WTB: 10K Alpha pot, dual log taper KT Swap Meet 3 11th May 2006 04:01 PM
Need info on Good dual-gang log and antilog pots groovietuner Parts 1 29th April 2005 04:54 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
