I need nearly identical potentiometer from mouser as this part RK0971221Z05 ALPS | Mouser
It has on-off switch, will be using it on d-amp, but need KNURLED shaft (will be ordering about 10), can someone point me to the correct product? can't seem to get around the website...
thanks,
thanks,
It's not likely that you'll find these as an off the shelf part. The knurled shaft is an option that manufacturers would order for production units.
But those alps or alpha's( really don't see a difference) I've searched for replacements and I would just buy some new knobs for it, they're hard to find. I needed te same size pots and elna's or nichicon's bipolars. Those large companies have few values in stock . kind of shameful.
Goodluck
Goodluck
