Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Anyone use magnet wire for point to point wiring projects?
Old 2nd February 2004, 08:11 AM   #11
eeka chu is offline eeka chu  United Kingdom
The lacquer you mentioned elizard is similar to potting compound. Delicate windings are sometimes dunked in it to help keep them safe, lead guitar pickups for example.
I was reading something related to this thread last night on an amature radio builder's site.
One of the radio builders mentioned that he had used thin coiling wire and said he removed the coating by the following method...
- Clamp iron to edge of desk somehow so that the tip hangs over the edge of the desk
- Put something hot solder proof underneath the tip, like a wet sponge
- Load the tip, which I expect has to be a bevel or chisel shape, full of solder; until it begins to drip off
- Take the end of the wire and move it into the liquid solder
- Wait until the solder or wire begins to turn black with gunk
- Gently move the wire back and forth in the puddle
- Remove the wire
He said he managed to get the wires to tin quite well. Whenever I have use this wire before I'm always left questioning just how clean a join it could be with that much gunk floating around while it was being made. Last time I used it I'm sure I saw about twice as much gunk floating on the solder as there was solder there.
John
Anyone use magnet wire for point to point wiring projects?Hide this!Advertise here!
Point to point wiring help chrish Tubes / Valves 26 17th August 2007 07:52 PM
Wire Wrap connections for point to point mashaffer Tubes / Valves 10 7th July 2007 01:11 PM
Benifits of point to point wiring for digital circuit? MGH Digital Source 15 14th September 2006 10:17 PM
Audio Note's Kit One done in point-to-point wiring Wram Tubes / Valves 18 29th April 2003 10:59 PM
Point to Point wiring HarryHaller Everything Else 79 21st March 2002 11:15 PM
Copyright ©1999-2017 diyAudio
