Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 23rd January 2004, 08:03 PM   #1
Mr. Triatic's Avatar
Default 4570C and 5218A
hi guys (and gals)!
i have scanned the net for information/specs. on these devices (opamps) ...but nothing, does anyone have any clue regarding the specs.?
those little fellows are encapsulated in 8 pin DIP package.
Are they dual opamps or just single ones?
any HELP would be appreciated
kind regards
/Ludvig.
www.joddla.net/audio/
Old 23rd January 2004, 08:19 PM   #2
Tube_Dude's Avatar
Hi Ludvig!
They are dual op amp and bipolars...i never find nothing about them in the net.
They are very much used by the majors japonese manufacturers.(Pioneer , Onkyo,etc) in the phono input stage!
Is not much , but is all i know!!
Jorge
Old 23rd January 2004, 08:28 PM   #3
wonderful!
then i probably can replace them with a dual OPA2134...?!
the victim is a Denon DA-500 DAC, i ripped off the cover and spotted those opamps...
Cheers mate, thanks for the quick reply!
/Ludvig.
Old 16th February 2005, 11:30 PM   #4
EIRA is offline EIRA  Netherlands
EIRA's Avatar
Hi Ludwig... I planned to change these M5218 as well. Did you do it (back then in 2002)? and did it work out satisfactory?
Old 17th February 2005, 10:34 AM   #5
Leolabs is offline Leolabs  Malaysia
Leolabs's Avatar
Send a message via MSN to Leolabs
If i was not wrong,datasheets of both are available at www.datasheetarchive.com.Personally for replacement of them,i will try any dual audio OP-AMP as long as pins compatibility is not an issue.
Old 17th February 2005, 01:05 PM   #6
macboy is offline macboy  Canada
You'll have more luck searching for M5218 (with A, AF, or AFP suffixes) and NJM4570 or JRC4570.
Old 19th February 2005, 07:08 AM   #7
EIRA's Avatar
Default M5218
I found the datasheet here: http://www.datasheetarchive.com/sear...218&sType=part
I changed the 5218 (slew rate 3 V/us) by and OPA2134 (slew rate 20 V/us) and put two larger capacitors in the power supply. A great improvement. more power in a shorte base, more open sound, more solid, softer mid. Absolute worthewile the 10 Euro's I paid for the 2134!
Page generated in 0.08219 seconds (77.25% PHP - 22.75% MySQL) with 9 queries
