Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
What  component can cause speaker crackling?
Old 12th December 2014, 12:21 AM   #1
XsamuraiX is offline XsamuraiX  United Kingdom
Default What component can cause speaker crackling?
Hello.....
Just wondering, what actual component in a preamp can cause loud crackling feedback on speakers?
It's not the power amp at fault as it's been tested with another preamp and all is fine...
Old 12th December 2014, 12:29 AM   #2
billshurv is online now billshurv  United Kingdom
billshurv's Avatar
cone rubbing? push the woofers gently with your fingers and listen for scratching sounds.
Old 12th December 2014, 12:46 AM   #3
I tried that, but the speakers are fine working with the other preamp, so I used a 2nd pair of speakers to double make sure, and the same thing, speakers are fine, no crackling using another preamp, and, I did test the speakers by doing what you said, it made no difference, my guess is, maybe a cap has gone bad, like, the KEF subwoofers, crackle loud and buzz when a certain cap goes bad, I'm hoping it's the same theory...
Old 12th December 2014, 12:59 AM   #4
billshurv's Avatar
in that case certainly power supply is the first thing to look at.
Old 12th December 2014, 07:35 AM   #5
Yeap, I tested the mains supply to see what type of voltages were coming in and that is all ok, I also tested the mains transformer inside the preamp, all again again. I know I'll have to end up removing caps but it is a pain in the butt!!! can't test them in circuit...
Old 12th December 2014, 07:39 AM   #6
Mooly's Avatar
Failing transistors can be a cause of noises/crackles too. Have you looked for more obvious things like dry joints ? If its a cap then I would be looking at small ceramic or tantalum types first.
Old 12th December 2014, 07:48 AM   #7
Hi Mooly, I haven't removed the main circuit board yet, been to busy, but will get on it today. The Preamp is around 14 years old almost, but, very good components were used as it was around 2k when it was new... I'll check caps and transistors today, what main points would I check caps? On output stages? Funny thing is, there is NO!!! crackling when I use the digital optical input, it only crackles when I'm using the phono stage inputs.
Old 12th December 2014, 07:51 AM   #8
The company that make it was Ditton, a English company, but they went broke if I remember, sold stock and the name to some company in China... So it's non existent to find a service manual or even the owners manual online...
Old 12th December 2014, 08:01 AM   #9
Mooly's Avatar
It sounds a bit different to the type of preamp I was imagining tbh.
As its much more modern then prime suspects could be SMD (surface mount) caps that have leaked. You need to have a good visual look at it all first. If its just the phono stage crackling (so line level OK ?) then it should be an easy fix to identify the phono section and repair/replace components as required.
Old 12th December 2014, 08:26 AM   #10
Ok, will give that a try ~Mooly and I'll get back with the results...
What  component can cause speaker crackling?Hide this!Advertise here!
SMAART 7, The Best Speaker Component In the World psemeraro Multi-Way 51 26th July 2012 03:11 AM
FS: Diamond Audio HEX S600S component speaker system Bronson_k Swap Meet 1 15th November 2009 07:12 AM
HT Speaker/Component Cabinet tfreer85 Subwoofers 2 31st July 2007 05:40 AM
JL Audio Component Speaker Sale Dominick22 Car Audio 0 27th April 2006 02:45 PM
Need help on speaker design, and component selection BrianGT Multi-Way 5 5th February 2002 04:39 PM
