| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
#21 | |
Hi Fred, There are real instances that you bias near Idss level eg MC phono amp. You can (should) even parallel a few of them to improve the noise performance. In real life you hardly get 30mA, that's the max Idss for that particular geometry of JFET. However, you do get lots of 22mA Idss from the V group. I do sell JFETs to DIYs and I sell them at all groups. Y, GR, BL, V, You name it. I stock a lot of V groups as well. At the moment, I don't have 2SK369 in stock. But I have 2SK364-all groups and 2SJ104-all groups. If anyone is interested, just pop me a email. bty I also have tonnes of 2SK246-BL and 2SJ103-BL, some 2SC5200-O and 2SA1943-O. I can match complementary devices to within 1% as well using my accurate bench top multimeter. I hope this info helps! James Yung Praise! Audio |
#22 | ||
And just one last question to prove I'm completely dumb. I still can't figure out if the so called "signal source resistance" (bottom right) is the impedance of the generator (signal source) or a kind of gate stopper resistor connected to the fet ? Sorry
/Cheff - Falling feels like flying, until you hit the ground |
#23 |
At the moment I posted that model, I was wrongly convinced that is the one that represents one high Idss 2SK369. (I do not use that model often and I messed it with the 2SK363 model I have and which does represents one high Idss 2SK363.) In fact, the model I posted has actually 9.6mA Idss. However, this is just fine with VTO=-.3552. Below is the Id vs. Vgs plot done with MicroCap. So, I would say that the transconductance vs. Id curve would look satisfying. Id vs. Vds plot curves are btw too flat as they are with the bulk of the JFET models (check the few other threads on this topic).
Pedja |
#24 | |
Hi James, All,
Just stumbled over this thread.. Quote:
I.e. VGSoff = C * Idss**alpha Yfs = C' * Idss**beta For example, the Sanyo 2SK772 datasheet has alpha of about 0.5 and beta of about 0.3 And I assume, 1/beta should always be near 1+1/alpha. Regards, Peter Jacobi
-- YMMV |
| FET's: LND150 and 2SK369 Substitutions ? | Jan Dupont | Parts | 13 | 21st November 2007 09:53 AM |
| Free Spice Or Cheap Spice Simulator-Where To Start? | kelticwizard | Everything Else | 29 | 15th February 2007 01:38 AM |
| D.I.Y. "Duplex" 2sk369 jfet mm phono preamp | doggy | Analogue Source | 6 | 26th September 2006 08:23 AM |
| 2sk170BL or 2sk369 for MC Stage | Panelhead | Solid State | 45 | 18th December 2003 10:50 AM |
| What about 2sk369 in place of 2sk170 in MC phono | giolight | Pass Labs | 2 | 24th February 2003 10:35 AM |
| Page generated in 0.10365 seconds (76.97% PHP - 23.03% MySQL) with 11 queries |
