| Home | Forums | Articles | Links | Blogs | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
We're saving for a new server - help us to serve you by Donating Today and become a friend with benefits!
Ads on/off / Custom Title / 2009 Tshirt / More PMs / Bigger Images / Advanced printing |
Thread Tools |
I am looking for a switching regulator to drive a 700mA LED. It must operate as a current source. Vin must be at least 40VDC. L6902D would be an excellent candidate, but Vin is only 36VDC. Does anybody know a part that would be a good solution for my application?
#2 |
Do a search at national semiconductors site for the LM317. In the data sheet they so how to use it as a constant current source. I think it's rated at 40v thou I don't think it would matter because in their fore mentioned schematic it is not connected to ground(regulating current not voltage). By the way, I use this set up to charge nicads...Works good.
#3 |
Thanks for the reply. L317 is a linear regulator. In my application I need to drop 30V at 700mA. Power dissipation is 21W
, which is not acceptable.
#4 |
Switching regulator, not linear. I guess for efficiency, but 40V supplies usually have plenty of current to spare. And what LEDs take 700mA???
Tim
See my Electronics webpage -- the home of Vacuum Tube Drag Racing. The key to being a successful Audiophile: "I reject your reality and substitute my own!" "It's all in your head. So follow your head. Don't bother trying to explain it, because there is no explanation. Likewise, disregard any who try to explain it, because they're most likely way off the mark." - Myself |
#5 |
Linear Tech has an application note for "Current Sources for Laser Diodes" -- you will find schematics, the entire shooting match for CCS using both linear and switched regulators.
If it is a design where "metrics" are important you will probably want to consider using the Linear LT1533 slew controlled switching chip with post regulation. by the way, Linear now sells their stuff, fewer than 500 pieces, direct to the DIY'r -- and prices are about 40% less than Digikey -- shipping is via FedX. |
#6 | |
depends upon how many candela you want. |
#7 |
Account Disabled
unrelated questions: do we know if LEDs wear out? assuming that they are working within their spec.
I personally haven't experienced any worn LEDs but others have. |
#8 | |
#9 |
Ya, my bad....I was focused on the word "LED" not "700ma". I gotta agree with Sch3mat1c......700ma is alot for a LED, unless your planning on putting a bunch in parallel. Since you got so much voltage why don't you hook em' up in series. You could daisy chain quite a few LED's on 40v.
#10 |
And another thing, a linear regulator would be just fine because "40V supplies have plenty current to spare". I mean.. designing a 21watt constant current (SWITCHING!) supply for a LED is not worth it, and why constant current anyway? If a constant voltage is put across a LED, a constant current would flow thru it. nuff said.
| Thread Tools | |
| Switching current source for Class A? | QED047 | Solid State | 97 | 2nd September 2009 10:10 PM |
| Switching Regulator design Questions | fr0st | Parts | 19 | 19th November 2007 02:51 PM |
| Aleph-type current source, but source follower this time | tschrama | Pass Labs | 4 | 29th July 2005 01:55 PM |
| Source follower electret mike -> use with current source? | capslock | Solid State | 1 | 28th February 2003 01:54 PM |
| Using Ixys current regulator as current sink. | G | Solid State | 3 | 16th November 2002 11:23 AM |
| Page generated in 0.47547007 seconds (36.46% PHP - 63.54% MySQL) with 10 queries |
