Diode identification - diyAudio
Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 8th November 2014, 11:51 PM   #1
Default Diode identification
These diodes were in a modified Dynaco 70 tube amp (to replace the tube rectifier). I've googled the numbers on the diodes but haven't come up with anything I can use.
Does anybody recognize them? They are quite large compared to the UF4007 I was going to replace them with. I'm new to electronics, but I am wonderign why they have a plastic housing?
Old 9th November 2014, 07:51 AM   #2
Elvee is offline Elvee  Belgium
Elvee's Avatar
A1423PM:
Vrm:6kV Io:300mA Vf:7.2V@100mA
(made by G.E.)
. .Circlophone your life !!!! . .
♫♪ My little cheap Circlophone© ♫♪
Old 9th November 2014, 09:38 AM   #3
JonSnell Electronic's Avatar
The original rectifier (5U3 etc) has a forward voltage drop of some 35V or so. A UF4007/1N4007 has a forward voltage drop of just 0.7Volt.
Do you think it wise to possibly exceed the HT maximum voltage across smoothing capacitors etc? Check the warm up/off load HT before running for any length of time!
Support for Fender, Marshall and all Valve Equipment; Audio Innovations, Audiorama FU29, Quad and Leak. www.jonsnell.co.uk
Old 9th November 2014, 09:53 AM   #4
JMFahey is offline JMFahey  Argentina
JMFahey's Avatar
^^^^^^^^^ check that.
Looks like a typical "audiophile Mod" to me, where a functionally correct (and originally specified) part is replaced by some "exotic" , in the futile attempt of somehow "improving sound".
Here they used a 6kV diode pack (there's not even 1 kV around there so 1kV 1N4007 is fine), it has only 300mA capacity instead of humble 1N4007 1A , the problem is not so much the average current but the initial capacitor peak charging current, there's also whay Jon points out: +V will be higher than designed ... will filter caps stand that? (although maybe they also used 6kV caps )
Oh well .
Old 10th November 2014, 03:33 AM   #5
Thanks for identifying them. I didn't realize they were such high voltage but lower amperage.
The amp is using 525v filter caps, so I think I will be ok.
Thanks again
Diode identification mika111 Car Audio 2 19th December 2013 07:57 PM
Diode Identification Help Needed TheOtherBob Car Audio 7 17th May 2013 07:47 AM
Parallel diode vs antiparallel diode phieuxuatkho Class D 6 31st October 2010 12:54 PM
Diode Identification the intimidator Chip Amps 4 14th May 2010 09:17 AM
hybrid power supply: diode bridge into diode tube engels Tubes / Valves 8 24th September 2007 09:18 AM
Copyright ©1999-2017 diyAudio
