tkd 2cp2508 vs. stepped attenuator - diyAudio
Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 4th November 2014, 11:49 AM   #1
greg7 is offline greg7  United States
Default tkd 2cp2508 vs. stepped attenuator
Which of these would be sonically superior? The stepped attenuator would be using metal film resistors. Couldn't find anything searching here. I'm building a tubes4hifi preamp kit and it comes stock with mono gain attenuators (which I'm also debating replacing with Alps blue mono's or TKD 2cp600) and the main attenuator, which is 23 steps.
Old 5th November 2014, 08:00 AM   #2
Hand wired resistors around a rotary switch can have capacitive feedthrough, depending upon how they're physically placed. Also, the wiring that sends the signal to the attenuator and receives it from the wiper can also be messed up.
The point is that it's hard to state in any absolute sense how well it will work out, since specific switches with carefully done layout can work really well, and a fool who knows nothing of the potential problems can end up constructing an attenuator whose frequency response can vary at each step.
These problems can generally be avoided by using low valued resistors and a tight, clean layout, and also by using proper shielded twisted pair for the input and a separate piece for the output, to minimize capacitive feedthrough.
Short summary: the TKD will be simpler, but the hand built attenuator will probably work better if you don't mess it up! Plus, you get to decide the gain of each click, whereas the TKD decides that for you.
Best of luck!
Good source for TKD stepped attenuators Steve Eddy Parts 7 10th January 2010 12:21 AM
FS - TKD 10K Stereo Stepped Attenuator - NEW Algar_emi Swap Meet 6 21st December 2009 10:44 PM
TKD (TOKYO KOON Denpa) 2P65CS very highend stepped attenuators Shalimar Swap Meet 9 25th May 2008 07:42 PM
WTB: TKD stereo Stepped Attenuator kudret Swap Meet 2 22nd November 2004 07:46 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
