Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
First build, Going with OB from older thread
Old 21st September 2014, 09:40 PM   #1
Oddio is offline Oddio  United States
Default First build, Going with OB from older thread
So, I want to make this OB speaker because its ideal for mye at the given moment (easy to build, relatively cheap).
This is my first home audio build ever (have done a few caraudio installs and speaker box builds).
The thread I am referencing is here:
http://www.diyaudio.com/forums/full-...le-la-mjk.html
I have to place an order for some parts from PE and wanted to try and get all of these done together, the parts required are listed:
I just wanted to make sure I am getting the correct parts here, and I am linking to the part I found.
Peerless SLS 830669 - 12" Woofer
GRS 12PF-8 12" Paper Cone Foam Surround Woofer
Was going to try this Woofer, what you think?
Seas 27TDFC tweeter
Looking for a cheaper alternative
Sledgehammer 12mH 15 gauge inductor
*** Cannot find this at PE
0.8 mH aircore inductor
Jantzen 0.80mH 20 AWG Air Core Inductor Crossover Coil
12uF film capacitor
Dayton Audio DMPC-12 12uF 250V Polypropylene Capacitor
25 ohm 5W resistor
25 Ohm 5W Resistor Wire Wound 5% Tolerance
Do these parts look correct? I admittedly done know much about these parts, and the difference between the different models I am finding online.
Also, is there a "cheaper" yet still quality tweeter I can replace that SEAS with? Anyone have experience?
Old 25th September 2014, 08:39 AM   #2
gmphadte is offline gmphadte  India
You are in the wrong forum...parts!!!
Gajanan Phadte
First build, Going with OB from older threadHide this!Advertise here!
OB sub build??? totalcomfort Subwoofers 7 29th March 2014 07:30 PM
Yet Another Newbie First OB Build jazbo8 Multi-Way 4 28th August 2011 10:05 AM
Newbie with first build OB dieseldust Introductions 4 26th October 2010 04:02 AM
OB rear wave cancellation thread. chris661 Multi-Way 1 22nd July 2009 07:06 PM
Copyright ©1999-2017 diyAudio
