Long, narrow chassis for monoblock? - diyAudio
Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 24th August 2014, 08:37 PM   #1
SonyFan is offline SonyFan  United States
SonyFan's Avatar
Default Long, narrow chassis for monoblock?
I'm having a really hard time finding a long narrow chassis to build a mono amp in. I can find slim chassis but they are all full width and I am using EI transformers so they are not an option. I don't want to put everything in one box and I don't need two hulking boxes to lug around either so full size is out of the question.
The style I'm interested in is like these, more or less
I would prefer that it not have external heat sinks, I think they are tacky. If it does have a heat sink exposed it would help if it were only on one side, or else one will go unused. Anyone know where to find something like this? If they are scarce I'm not picky.
"You lose, Rickles!" - Jim Lahey
Old 25th August 2014, 09:28 PM   #2
Andersonix's Avatar
Have you seen these Hammond chassis?
http://www.hammondmfg.com/jpeg/1441BKU_B.jpg
Hammond Mfg. - Steel Chassis & Bottom Plates (1441 & 1431 Series)
They can be combined with perf covers of different kinds (flat or box) and used in any orientation.
Old 25th August 2014, 10:16 PM   #3
Support your local sheet metal worker.
Old 26th August 2014, 09:56 AM   #4
I also like that shape:
https://plus.google.com/photos/11771...35790865674737
Old 28th August 2014, 12:56 PM   #5
SonyFan's Avatar
Originally Posted by oshifis View Post
If I were going to build a tube amp I think that is about how it would come out.
Old 1st September 2014, 03:35 AM   #6
Bare is offline Bare  Canada
The ACA Chassis It's even 'in stock ' :-)
Amp Camp Kit - Kits
Old 1st September 2014, 11:46 AM   #7
SonyFan's Avatar
Originally Posted by alexxie110 View Post
So you need existing chassis instead of tooled part or CNC part, right?
Yes I'm on a budget.
Old 1st September 2014, 11:48 AM   #8
Old 1st September 2014, 04:57 PM   #9
A local CNC laser job shop charged me ~$120 to cut out the panels for 6 cabinets from a 0.050" thick 4'x3' 5032 Aluminum sheet. This was basically their lot charge. I had to supply the material. You could probably cut 0.125" panels for a similar lot charge. Making it pretty is another matter. You can grain it manually (sand paper) but it may not have the machined look of their graining machine (another lot charge). I found a service mentioned here called Front Panel Express, but they look expensive. I would like to set up a service to do cabinets in lots that would distribute the costs and make it less expensive, but there does not look like there is enough interest. The biggest expense I have found in sheet metal is custom bending. Using extrusions can get around this, which is part of what Front Panel Express offers. There is a blog piece on EETimes that discusses this some more.
Low-Cost Cabinet Solution for Prototype Systems | EE Times
Hope this helps. Would like some feedback.
Old 1st September 2014, 05:25 PM   #10
Default Custom Chassis Option
I tried posting a reply using "quick" but it did not seem to post. Apology if this becomes a duplicate.
A CNC industrial laser job shop local to me charged ~$120 to cut the panels for 6 different electronic enclosures from a 4'x3' 0.050" thick 5052 Al panel. This is basically their lot charge. I imagine you could cut 0.125" thick panels for similar costs.
Making bend in cut pieces precisely enough can prove to be a challenge even if you have access to a press brake. Easier to use extrusions, but using stock extrusions has aesthetic limitations and potentially sharp edges (depends if you put inside or outside). A service that I found here, Front Panel Express, has a "pretty" system but they are pricey from my perspective.
To use any of these you will need to design the cabinet in some for of CAD. Front Panel Express appears to have a free tool. I do not know how well it supports importing CAD models for components so that you can get holes to line up and check for interference.
There is another service option that I have proposed that would probably enable making the specific cabinet you want with a descent finish for about ~$85. So far not much interest. You can read about it on EETimes in the Prototype blog.
Hope this helps.
Where to Buy nice looking monoblock chassis? solviken Solid State 23 4th April 2012 03:28 PM
monoblock vs. one chassis? Magnetmaz Tubes / Valves 49 17th June 2005 06:42 AM
2x long but narrow coffin style flightcases FOR SALE!!! Bull Swap Meet 1 28th April 2005 09:22 PM
Long, narrow electrostatic tweeter for line array Bill Fitzpatrick Planars & Exotics 13 29th October 2004 09:33 PM
Copyright 1999-2017 diyAudio
