how stable is the parallel resistance of an electrolytic? - diyAudio
Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 17th August 2014, 05:23 PM   #1
Default how stable is the parallel resistance of an electrolytic?
Capacitors leaks current.
So a real world capacitor is like an ideal capacitor with a parallel resistor (of course, series resistor and inductor, too.).
The parallel resistor value seems to be high in some capacitor (10000 MOhm) and low in some electrolytics (less than one MOhm).
Anyway, it that parallel resistor value stable with time (many years) and temperature as long as the capacitor is used well within the temperature and voltage spec?
Old 17th August 2014, 05:38 PM   #2
Often, the leakage current is given by 0.03*C*V or 3uA whichever is greater.
So the parrallel resistor will be 1/(0.03*C).
For example, an electrolytic capacitor with the spec of 470uF, 25VDC, will have a parallel resistor larger than 0.071 MOhm?
Is this the right calculation?
Anyway my question is whether that resistance value is constant over time, temperature variation (but far below 85 degrees C), etc.
Old 17th August 2014, 08:46 PM   #3
JonSnell Electronic's Avatar
One should presume infinity resistance or the capacitor is leaky.
Support for Fender, Marshall and all Valve Equipment; Audio Innovations, Audiorama FU29, Quad and Leak. www.jonsnell.co.uk
Old 17th August 2014, 08:52 PM   #4
jcx is offline jcx  United States
Electrolytic Caps are best applied where their variable and/or poorly speced characteristics don't cause problems
leakage current which can be indicative of parallel R is highly variable with temp, age - high leakage is often is often speced as one of "end of life" numbers
Old 17th August 2014, 08:52 PM   #5
Banned
Measured by what equipment ?
Do you own an LCR bridge meter ?
Old 17th August 2014, 09:00 PM   #6
No, that resistance varies all over the place, with age, temperature, on-time and anything else you can think of. It's an interesting exercise to set up a power supply and measure leakage current with a series resistor and DVM. Do it. Vary everything and see what happens. You'll learn a lot.
BTW, I don't think you have this problem, but don't confuse the simple parallel loss model with the DC leakage resistance term.
I may be barking up the wrong tree, but at least I'm barking!
Old 17th August 2014, 09:53 PM   #7
I read the specs avaliable at Mousesr.
Old 17th August 2014, 09:57 PM   #8
Banned
Those specs are generic, nothing that you can use in sound applications.
Old 17th August 2014, 09:59 PM   #9
If parallel resistance is acceptable, you just need to know what it is?
You could put a known stable resistor (perhaps 100K) in parallel.
That should swamp the unknown possibly non-linear component.
Old 17th August 2014, 11:24 PM   #10
If the parallel resistance changes (with age, temperature, etc.) +/- 60% from 1000 MOhm, it would not matter much for me. If it changes +/- 60% from 0.2 MOhm, it matters.
Experience with anti-parallel electrolytic capacitors? majerjack Analog Line Level 19 24th June 2014 11:50 AM
Parallel TDA2052 vs Parallel LM3886 for subwoofer goldyrathore Chip Amps 24 21st October 2013 05:50 PM
Question about wattage of resistance in parallel Rotus623 Solid State 2 22nd November 2010 04:15 PM
Is this stable?? Leolabs Solid State 1 27th November 2006 01:23 AM
Parallel amps & Parallel Voice coils? officeboy Multi-Way 7 26th May 2004 07:12 PM
Copyright 1999-2017 diyAudio
