Beginner help with resistor and color code - diyAudio
Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 8th August 2014, 02:05 PM   #1
Unhappy Beginner help with resistor and color code
I'm really freebie with electronics as you can read in title of the post.
I want to try to make something easy and i found this project for a simple pedal compressor.
Anyway I'm done with everything except for two easy step (not for me ):
- I need two resistors one 2k4 (2.4k) and one 4M7 (4.7M) I bought all the components in a shop with the part lists so I have these two resistors but I'm not sure are as the specs.
- what does it means these symbols for the jack? I have to wire the ground to the ring and then!?
and what does it means the arrow above the fet?
Really thanks a lot.
Old 8th August 2014, 02:12 PM   #2
Mooly's Avatar
The FET is an N Channel JFET or junction FET like a 2N3819.The little arrow on the gate pointing inward means its N channel. The big arrow above the FET simply means that connection goes off to somewhere else on the circuit.
The jack symbols are a bit........ well unconventional maybe......
The little arrow seems to imply a switched connection. It can connect to one or other of the two dots to make a circuit.
Quite where they all go depends on the actual circuit.
The 10K with the arrow is a variable resistor like a volume control.
Does that help
And the pictures are to small to make the colours out on the resistors... measure them on your meter.
Installing and using LTspice. From beginner to advanced.
Old 8th August 2014, 02:20 PM   #3
Default thanks for the quick answer
sorry I uploaded the small pic
Old 8th August 2014, 02:22 PM   #4
P.S.: yes is the switch for the bypass. Thanks a lot again.
Old 8th August 2014, 02:26 PM   #5
picowallspeaker's Avatar
24 k Ω ??
Resistor Color Codes & Component Identification
Edit: add another zero, so it's 240 KΩ.
Old 8th August 2014, 02:53 PM   #6
post3 ,
is it red, yel, org, brn, brn?
2, 4, 3, 1, 1
I think it is
2430 1% - for first digit, second digit, third digit, multiplier, tolerance. to 5band resistor code and 243 fits the E96 values.
I don't think it is 5 band including tempco - for first digit, second digit, multiplier, tempco, tolerance
= 24000 tempco 1%
regards Andrew T.
Old 8th August 2014, 03:28 PM   #7
Enzo is offline Enzo  United States
The arrow pointing straight up from Q2 means a connection to the power supply. Probably a positive supply like +12v or +15v.
When a whole bunch of things all connect to the same power supply, instead of drawing the lines all over the schematic, they just do something like that arrow. The -15v might be an arrow pointing downward.
Old 8th August 2014, 05:33 PM   #8
tonepad -- file information
the complete schematics it there.
I bought the right resistors.
Now I need just to understand what is that arrow.
Really thanks to everybody for your help
Old 8th August 2014, 05:40 PM   #9
Mooly's Avatar
From your link I just see a circuit for a DC-DC convertor using a MAXIM 1044 chip. The effects part of the circuit doesn't seem to be showing.
You can see a similar arrow on the 9 volt battery in that image.
Old 8th August 2014, 09:57 PM   #10
If you are asking about the arrow by Q2, I don;t see Q2 on the schematic you linked.
I am still sticking with : it means the positive power supply.
Opt color code identification (Onetics) tubo Tubes / Valves 2 18th December 2013 01:17 PM
wiring color code Mosquito Tubes / Valves 3 30th November 2012 09:37 PM
Amp Wiring Color Code gingertube Tubes / Valves 13 29th May 2010 12:42 AM
Color Code Rodeodave Everything Else 3 22nd July 2008 12:40 PM
Quicksilver M135 Output Transformers Color Code? dshortt9 Tubes / Valves 2 13th October 2006 09:52 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
