Looking for IEC inlet datasheet. - diyAudio
Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 18th July 2014, 04:19 PM   #1
rol is offline rol
Default Looking for IEC inlet datasheet.
I am designing a small PCB that mounts directly on the tabs of the IEC inlet. Searching a while on the web, I could only find datasheets that show dimensions of the inlet itself, not the tabs. Does anyone has a datasheet that clearly shows positions and dimentions of the 3 tabs?
This is the specific inlet that I am using. Very generic one and I am pretty sure many producers have the same one.
6200.2100 Schurter | Mouser
Rol
Old 18th July 2014, 05:54 PM   #2
Duh!
Click on your link for the datasheet. Page2 shows a mechanical drawing! With dimensions!!
Old 18th July 2014, 10:38 PM   #3
Enzo is offline Enzo  United States
No, he is right, the drawing does not show the dimensions of the terminal spacing.
So get your IEC thing, then press the terminals into a piece of soft wood or a piece of paper or cardboard or even aluminum foil. SOmething it will leave an impression in, then there you will have a pattern to measure.
The dimension of the terminal tabs themselves are on there. You decide if you want the larger push-on size or the smaller solder size.
Old 19th July 2014, 01:58 AM   #4
amc184 is offline amc184  New Zealand
amc184's Avatar
You're right rol, those dimensions aren't shown. Here's a screen capture of the manufacturer's DFX of the part with additional dimensions drawn in (part centreline to tab centreline). Hope it helps.
Inside Classic Audio, my blog on repairs, modifications and anything else to do with audio.
Old 19th July 2014, 03:24 AM   #5
Perhaps that is easier than what I suggested...
Old 19th July 2014, 03:35 PM   #6
rol is offline rol
Thanks, that does help.
Wiring an IEC inlet mourip Parts 5 31st January 2013 06:02 PM
What do you think about filtered IEC inlet? rg12 Parts 4 15th August 2010 09:59 PM
IEC Inlet with or without line filter for CD transport? pooya Digital Line Level 7 23rd August 2009 06:58 AM
IEC Inlet filter issue jkeny Solid State 23 2nd August 2008 04:31 PM
IEC Inlet Filter confusion jkeny Power Supplies 0 31st July 2008 09:17 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
