Some advice please - diyAudio
Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 12th June 2014, 01:18 AM   #1
jwhisl is offline jwhisl  United States
Default Some advice please
Hello all! I am getting ready to start a portable blue tooth speaker project. I already have some small speakers and ive been looking at this Online Shop Stereo Bluetooth audio receiver / receiver board / receiver module / audio speaker amplifier dedicated DIY|Aliexpress Mobile because I like the idea of having buttons instead of knobs. Does anyone have experience with this product? I'm also looking for passive radiators, preferably rectangular around 2x3" size if anyone can help there. Thanks.
Old 12th June 2014, 03:47 AM   #2
Here's a few pictures of the speakers I'm thinking of using. They were in a soundbar mounted to a 32" flat screen. I don't remember the brand but they sound pretty good. Each of the 4 woofers are rated at 5w 8ohm and the tweeters are 10w 4ohm. The only thing is have no idea about frequency response because I don't know the brand.
Old 12th June 2014, 06:48 PM   #3
Meeeh, I don't think that this is the best speaker to use... For amplifier, use the mini usb PAM class d from ebay, together with the cheap ebay power bank.
Old 12th June 2014, 06:48 PM   #4
Also, these cheap BT recievers don't sound very well!!!
Old 13th June 2014, 03:33 AM   #5
Yes I agree the speakers in the picture probably won't be used now. I tested them with a small 6 watt amplifier and they were distorting a bit. I could use them as highs but I would still need designated woofers. I think I found a 5.25" peerless passive radiator that I like but I still need to decide on main speakers. What bluetooth module do you recommend that would be somewhat easy to wire to a small amplifier? I'm looking to run about 10-15 wpc (rms)
Old 15th June 2014, 02:00 PM   #6
Ok new question: what kind of potentiometer should I use? I think I need an audio taper potentiometer but I dont know if I need a 250k or what. Any advice?
Old 16th June 2014, 11:19 AM   #7
10-50k should be fine.. I use 50K log. pots in my amps, they work just fine..
15WPC is too much.. 2x3W is enough for big room with efficient speakers..
Old 18th June 2014, 12:25 AM   #8
bknabe is offline bknabe  United States
Default Bluetooth amp
I have 3 of these for sale on ebay currently
TDA7377 2 x 20W Stereo Amplifier with Built in Bluetooth | eBay
I use one to power a pair of foam core board speakers i have in my garage! These have a 50k audio taper pot I believe.
Bob
Old 18th June 2014, 12:33 PM   #9
jfresh is offline jfresh  Australia
I've been using XS3868 Bluetooth module for my portable mini speaker project aka (Pocket Horn) & PAM8803 as the amp, using 3.7v Li-Ion Battery & in-build usb charger.
The Bluetooth module cost around $5.
Here's the Pic, hope this help.
Click the image to open in full size.Click the image to open in full size.
Old 18th June 2014, 01:54 PM   #10
Jfresh:
Looks really cool. How do you connect the BT module and the amp to a single battery and avoid a ground loop issue?
Bob
Need some advice where to install LED, also power socket advice. Mull3t Construction Tips 14 28th May 2012 04:32 PM
new and in need of advice turboak Introductions 1 10th June 2011 02:32 AM
New and looking for advice Number One Chip Amps 10 26th February 2011 08:30 PM
Just after some advice... Michael2007 Multi-Way 2 6th April 2007 03:56 AM
Poster in Musical Instrument forum needs bridging advice on BrianGT 4780 advice moving_electron Chip Amps 0 16th February 2005 12:37 AM
Copyright 1999-2017 diyAudio
