| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Hi guys,
I'm working on a studio monitor project and I have a wack of transformers I've pulled from all kinds of equipment. I plan on using toroids from Plitron in the final assembly but I wish to find some transformers suitable out of my surplus pile. Most are EI laminate type (the big, bulky, unshielded kind). I wish to test the transformers to find out their ratios and other characteristics. I'm a 4th year EE but we never really covered transformers (or anything else in the program for that matter...) and I don't really want to just plug them into the mains for fear of blowing a house fuse. Should I use a signal generator and power amplifier as an input signal? And what sort of signal level should I adjust it to? Pete |
#2 |
diyAudio Moderator Emeritus
You need a variac.
Rodd Yamashita |
#3 |
The voltages are easy enough to work out. It's the VA rating that always bugs me. That's based on how many amps the transformer can safely take which is a question of heat dissapation. I sdupose you could estimate roughly based on mass but that's likely to have a big margin or error. Testing to destruction is one way but not very satisfying.
| Determining ratings for unknown Power Transformers | boywonder | Tubes / Valves | 3 | 22nd April 2009 10:27 PM |
| amplifier for unknown output transformers? | tonskulus | Tubes / Valves | 20 | 9th December 2007 11:36 AM |
| Testing Crossovers w/ unknown component values | THUMP LUMP | Multi-Way | 3 | 16th August 2007 03:41 PM |
| Measuring Unknown Transformers | Steven-H | Tubes / Valves | 3 | 5th March 2007 10:31 PM |
| Evaluating Unknown Power Transformers | wrenchone | Tubes / Valves | 10 | 14th July 2006 04:04 PM |
| Page generated in 0.07463 seconds (78.42% PHP - 21.58% MySQL) with 11 queries |
