Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Best budget resistor for gainclone?
Old 19th May 2014, 12:24 AM   #1
bdiermeier is offline bdiermeier  United States
Default Best budget resistor for gainclone?
Hello!
I am about to start my second and third amplifier builds, an lm3875 and lm4780 from Audiosector. I already have the PCBs, and decided to get my own components as opposed to the kit, because I think it's part of the fun of building!
My question is, what do you all recommend here for resistors, with a budget in mind? I really don't even know what tolerance is appropriate, if I can get away with 5%, or if I should use 1%. I have been looking at Vishay's offerings, and they seem to be the top choice, but all the different series are starting to get confusing!
So, what would you recommend for these circuits in the $1 to $2 range, or less? Also, I'd prefer it be a series stocked at mouser or digi-key.
Thanks!
Old 19th May 2014, 02:31 AM   #2
Michael Bean is offline Michael Bean  United States
Michael Bean's Avatar
Here's what I usually use: http://www.digikey.com/product-searc...=0&pageSize=25
Mike
Old 19th May 2014, 03:04 AM   #3
Originally Posted by Michael Bean View Post
Here's what I usually use: Invalid Request
Mike
Those are actually what I used in my first amp! Beginners luck I guess, because they were just a random, uneducated pick at the time. They seem to work well, and it's good to know a good option isn't very expensive. How do they compare to something such as Philips/Vishay BC MRS25 resistors? Would I notice a difference, for better or worse? IDK why, but those Vishay's just really appeal to me...
Old 19th May 2014, 04:22 AM   #4
IMHO the Yeago's are 1% - 100ppm, just fine for most line level audio applications. If you need resistors with tighter tolerance or lower noise, they have those too, at higher prices of course. Some members here will claim that ferrous materials, which these do have, will irreparably harm the sound, but unless you're building giga-Hertz audio gear, I don't think it's an issue. (Now I've done it...time to put on the flame retardant suit ) I've used both and don't see any reason to spend more than necessary.
Mike
Old 19th May 2014, 04:35 AM   #5
Mike
Awesome, thanks for the reply, its nice to get some good information that isn't way beyond my knowledge level. Looks like I'll be ordering some Yeago's.
Old 20th May 2014, 12:41 AM   #6
Mike
I didn't notice earlier, but those aren't available in 1/2 watt. Do you have any 1/2 watt recommendations?
Old 20th May 2014, 12:45 AM   #7
They have these, same specs - 1/2 watt: Invalid Request
Mike
Best budget resistor for gainclone?Hide this!Advertise here!
Which resistor type for emitter resistor? sajti Parts 25 8th April 2009 06:12 AM
Why does the inverted gainclone have a resistor at the output goldyrathore Solid State 10 12th April 2005 11:36 AM
Help i'm on a budget!!!! Dannyball Multi-Way 28 27th May 2004 04:40 PM
Gainclone output resistor aeronaut Chip Amps 17 7th May 2004 09:26 PM
screen-plate resistor and grid leak resistor metebalci Tubes / Valves 4 26th February 2004 03:18 AM
Copyright ©1999-2017 diyAudio
