I asked Epos for the spec of the resistor required in the crossover of my M12i speakers and I have been told to fit a
2.2ohm 5w metal film resistor
I found these on eBay
http://pages.ebay.com/link/?nav=item.view&id=190836822129&alt=web
But I imagine they are probably crap at 20p each including postage from Hong Kong...
I'm only after two. Where would be a good place to order from in the UK?
10 off 22r 500mW 1% metal film can be assembled into a radial 2r2 5W 1% metal film.
MUCH easier to find than 2r2 metal film 5W.
Solder two plain solid copper as uprights for the ten resistors to be soldered to.
You could place 5 above the PCB and 5 below the PCB, if you have room underneath.
