Rebuilding wire wound power resistors - diyAudio
Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 14th May 2014, 05:22 PM   #1
Default Rebuilding wire wound power resistors
I have a large wattage uniquely sized (round) resistor that needs to be rebuilt. I know that it is 180 ohms center tapped, and it's unubtanium and made to fit in a tight area. I removed some if the covering with a wire wheel and the wire is indeed broken in several places.
Does anyone know where I can find replacement wire and what kind of coating us on this thing? I believe its 300 watts.
Thanks,
Jeff
Old 15th May 2014, 10:33 PM   #2
Spiny is offline Spiny  United Kingdom
Spiny's Avatar
that looks like a vitreous enamel resistor, Ohmite are a maker though no circular ones now apart from Rheostats.
I think this will be nichrome wire (nickel chromium resistance wire)
alan
Old 16th May 2014, 03:04 AM   #3
DUG is offline DUG  Canada
Buy another 180-200 ohm and unwind it...you will not be able to re-use the wire on the one you have...or at least half of it.
Then find a pottery class and ask if you can enamel and fire your repaired resistor.
Doug We are all learning...we can all help
"You can't stop the signal, Mal. Everything goes somewhere..."
Old 16th May 2014, 03:21 AM   #4
Thanks for the advice, the coating seems to not be hard. I took a wire wheel and it seemed to come right off. I was thinking about trying to silver solder a piece of toaster wire between the couple of turns and see how close it was.
Old 16th May 2014, 03:40 AM   #5
Enzo is offline Enzo  United States
Some thoughts:
It almost looks like the element part of a rheostat, like they removed the wiper assembly.
What does it do? Is there a compelling reason a replacement could not be mounted remotely with three wires run to this space?
Old 16th May 2014, 10:58 AM   #6
If you have the capability to do that then it is a good idea...you could still use wire from another wirewound resistor...it may match the size better.
Old 16th May 2014, 12:11 PM   #7
I ran slot cars for a few years.
We wound our own controller resistors.
I used car exhaust sealer for as a very heat resistant adhesive. Never had a failure.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 16th May 2014, 12:46 PM   #8
It's actually for my wife's kitchenaid mixer. I am going to run to the surplus store tomorrow and see if there is a resistor that it can use to scavenge the wire from.
I had a hard time getting her to let me paint it candy apple red, now it has to look and work like new!
Mills wire vs. ceramic power resistors ro9397 Multi-Way 70 16th April 2014 04:31 AM
wire wound resistor MGH Parts 28 18th December 2012 10:05 PM
16ohm 10w ceramic wire wound resistors..... sippy Parts 3 19th August 2011 09:37 AM
FS: Vintage Precision Wire-wound Resistors theAnonymous1 Swap Meet 11 20th June 2009 09:41 PM
Wire Wound Pontentiometers - resistors neazoi Parts 1 12th January 2009 11:08 AM
Copyright 1999-2017 diyAudio
