Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Need help choosing capacitors at Elfa
Old 8th January 2004, 03:43 PM   #1
Alcaid is offline Alcaid  Norway
Alcaid's Avatar
Default Need help choosing capacitors at Elfa
Can anyone help me finding the capacitors best suited for an active crossover at elfa's webshop www.elfa.se
I'm going to use these resistors:
http://www.elfa.se/elfa/produkter/no/2012484.htm
thanks
Old 8th January 2004, 04:07 PM   #2
Notorious is offline Notorious  Netherlands
Notorious's Avatar
Hhehehe.. You have strange aproach to make things ..
I think you should decide first what kind of speaker would you like to build, and from there you can look for drivers and x-over..
But if you look in speaker section on this forum, than you'll find answers to all of your questions..
It sounds more like buying tires and asking what car you should buy that would suit the tires..
You might be a tubeneck if your date says "is that a tube in your pocket, or are you just happy to see me?" And it is a tube...
Old 8th January 2004, 04:40 PM   #3
Alcaid's Avatar
Read the post before answering, it's for an ACTIVE filter, not a passive.
Old 8th January 2004, 07:35 PM   #4
rikkitikkitavi is offline rikkitikkitavi
use any < 2,5 % tolerance, plastic film
(polyester, polypropylen e t c) condensator with fits both PCB and wallet.
There are plenty of both at Elfa.
/rickard
listen! Can you hear that ...
Need help choosing capacitors at ElfaHide this!Advertise here!
Help with choosing first kit candi.hansen Multi-Way 2 27th January 2009 11:47 PM
what is the difference between silver mica capacitors and ceramic capacitors ?? prorms Solid State 1 6th May 2008 12:38 PM
help on choosing a 1kw amp or better Hayden Solid State 5 17th September 2006 01:25 AM
capacitors: panasonic FC vs elna RJH vs rubycon ZA capacitors costiss Parts 11 30th January 2003 09:32 PM
differences between computer grade capacitors and small can capacitors LBHajdu Pass Labs 0 22nd February 2002 01:29 AM
Copyright ©1999-2017 diyAudio
