I have some isolation pads here for TO-3 and TO-220 cases.
These are those "new" synthetic (so not mica) pads. Do I need to apply thermal compound or not? I have some Arctic Silver 3 lying around.
I think these are the isolation pads I've got: http://www.aavidthermalloy.com/products/options/pads.shtml#insil
In case you don't know what the Arctic Silver 3 is: http://www.arcticsilver.com/as3.htm (this is supposed to be one of the best thermal compounds available for CPUs) (Thermal resistance: <0.005°C-in²/Watt )
Oh, btw, do I have to use the isolation pads on BD139 & BD140? I suppose I have to, since there's iron on the back of it, right?
Are you talking about the little rubber looking pads? I saw some of those when I was getting some Mica wafers for my transistors at the surplus store. I also saw some thicker opaque white ones for my transistors that were stuck to a plastic backing. You were supposed to peel them off, what are those?
- Design & Build
- Parts
- Isolation pads
