220v eq will it be on uk mians ? - diyAudio
Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 17th April 2014, 06:41 PM   #1
Default 220v eq will it be on uk mians ?
above
Old 17th April 2014, 06:55 PM   #2
Mooly's Avatar
Not necessarily. I've been checking our mains today as we are supposed to be involved in a CLASS trial over the coming months. Currently running at 247, and so on that basis a 220 volt rated product may well be unsuitable.
Installing and using LTspice. From beginner to advanced.
Old 17th April 2014, 06:58 PM   #3
O dam, thats not good what do i do?
Old 17th April 2014, 07:05 PM   #4
Refugee1's Avatar
Fit a 24 volt transformer with a high enough secondary currant to carry the load with the secondary in series with the primary of the appliance. It will up the voltage one way and reduce it the other way.
Old 17th April 2014, 07:08 PM   #5
sreten is online now sreten  United Kingdom
It probably will be absolutely fine assuming a standard regulator
supply for the op-amps. The regulators can handle overvoltage.
It will run a little warmer, no big deal, nothing to worry about.
rgds, sreten.
There is nothing so practical as a really good theory - Ludwig Boltzmann
When your only tool is a hammer, every problem looks like a nail - Abraham Maslow
Old 17th April 2014, 07:12 PM   #6
DF96 is offline DF96  England
Some Chinese 220V mains transformers may struggle with 240V, especially if they were intended for 60Hz too.
Old 17th April 2014, 07:28 PM   #7
I doubt it in a line level EQ box, unless its ultra cheap and nasty.
If so its probably doing more harm than good in the first place.
rgds, sreten.
Old 19th April 2014, 03:46 AM   #8
We have used voltage stabilisers in Malaysia for many years to cope with varying mains supply. These are basically a saturable auto transformer
Logitech Z5500 220V 50Hz to 220V 60Hz Montini Power Supplies 3 19th June 2012 05:44 AM
Is the YAQIN MS-12B (220v +-10%) safe to use in UK eldarvanyar Tubes / Valves 6 1st October 2011 08:14 PM
WTB : (80s) High End Preamp - 220V or 110/220V switchable Razorblade Swap Meet 1 13th January 2010 09:57 PM
Wanted: DIY Paradise Charlize, OR Decware Taboo (220V), OR Almarro A205 (220V) Jolojl Swap Meet 0 28th August 2006 11:31 AM
Autotransformer for 220v in the UK Pickledcreeky Everything Else 7 9th September 2005 05:39 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
